Results 1 to 26 of 26
    Mar 01 2016
    Houston
    New guy to Audi looking for build advice.
    Hey everyone, just a heads up to start with. Yes, I have searched all over for info. A lot of the info I've found has been very conflicting so I wanted to start a discussion here. I'm not new to building cars/trucks by any means. But this is my first Audi build. I will be doing a build thread at some point as well. But this is strictly for technical discussion.
    My car is a 1999 Audi A4 Avant Quattro 2.8/5mt. The car has 191k on it, runs and drives perfect. Has a few things here and there such as needing lower control arms and some trans mounts. I also have a mystery whine in 1st gear, but the trans is still super smooth. My plans are to daily the car as is besides some coilovers and wheels for now as I gather parts and info for a full build.
    The info I'm looking for here is for the motor and trans. My plans are to build the 30v 2.8 and PES boost it. Nothing crazy, but I plan on cams, possible shaved heads, forged internals, and around 10-12lbs on E85. I don't plan on going crazy, but enough to hold the power. I'm also interested in having the trans built to a certain degree.
    First things first, I've found some forged rods, but they say they are for the 2.7 and 2.8. Are they truly the same? I've searched this, but never found true specs to compare the 2.
    Second, what pistons would you recommend? What are the true specs I would need for a simple hone job, as long as the cylinders are in good shape which I expect them to be.
    This is just a start of my questions/concerns so please be patient with me!
    Thanks in advance!!
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    It would be cheaper to v8 swap.
    Sent from my Jailbroken iPhone 6s 9.0.2 using Tapashit
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Mar 01 2016
    Houston
    Knew someone would say it. I get that, but that's not what I want to do. Done many ls swaps, want to stay with the 30v since most people don't.
    Oct 09 2012
    Quote Originally Posted by James_720 View Post
    Have you found a supercharger already?
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Mar 01 2016
    Houston
    Not other than new from PES. Been checking eBay as well.
    Oct 09 2012
    they don't come up often used. good luck with your build. Please make a build thread to keep us updated.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Not gonna be a ton a info on these 30v builds. Main one I can think of is rezie from the now defunct genesis motorsports. A1, and a2 german has that car now if I remember right. As far as internals I have no real idea. Alot of parts will probably need to be custom ordered. Its not the best build motor to be honest but if ur set and have the money go for it. Most 1.8t cars that are built right have 10-20k into em anyways.
    You won't need a built trans as the 01a is good for ur power goals. Stage 3-4 clutch, jhm shift trio and mounts would be all you need unless your planning to mess with the diff to 4:1 or lsd. Maybe pickup a spare block to build and daily with shelf pes kit for now to see how you like it
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Hate to pop your bubble however the 2.8 V6 is the worst VAG motor ever built.
    Sure, it's reliable, all VAG motors where. It would be a better idea so swap a 2.slow with a turbo then the 2.8. It is literally the king of kings thee worst responding motor in VAG history to respond to induction.
    It was so excitiZzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz......... .............................
    The only way you'd do it is to be different, don't expect to be quick, it's "meh" and the power curve is so....linear, it's just so unappealing.
    Figured I'd luk.
    Dec 05 2007
    If you are going to add forged internals, might as well turbo it. It has been done before. Forged internal single turbo setup.
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Exacty what seerlah said. If you are going to source forged pistons, get different rods, and have the crank mains drilled for an additional two bolts, you can put down some power. Id say s4 intake and your choice of turbo or if you wanna spice things up, i have been wanting to do a centrifugal supercharger on my 2.8 in future... maybe you can beat me to it and try that out. your call but either way gonna cost a lot.
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    Quote Originally Posted by A1 A2 German View Post
    The only way you'd do it is to be different, don't expect to be quick, it's "meh" and the power curve is so....liner, it's just so unappealing.
    The 2.8 sucks because it has a linear powerband?
    Feb 28 2005
    Tempe
    And is weak and lacks any power.
    It has a very weak curve, there's no punch, and lacks any acceleration feeling. The only thing it has going for it is it goes right outta the box 0-35mph..it happens fast yet levels out to to the most power slow pull ever, the gear change to second would never chirp 2nd ever. There's no thrust. If the power band of a ko4's power band was the grade of a paved road no vehicle could drive up it as far too steep, if the charger 2.8 power curve was a road a golf chart could drive up it.
    Oh, pfff, yeah I see now...that's what I get for typing that out on my phone.
    Veteran Member Four Rings Murph_129's Avatar
    Dec 15 2014
    Indianapolis, IN
    I swear I've seen someone who was working on a 30V single turbo kit? Probably 034.. but I don't see anything on their site.. Just the 2.7T single turbo.
    -Murph
    11' A4 2.0T Quattro Premium+ Phantom Black - IE Stage2
    01' A4 1.8T Quattro Sport Silvaro - DazTuned Stage2 - SOLD
    IG: smurphy_iii
    Sep 30 2015
    Quote Originally Posted by Murph_129 View Post
    Yea cause their kit ran on a stock 2.8 which couldnt hold more than 8-10 psi. If you are building the engine, anything is possible.
    Dec 05 2007
    The STK for the 2.7t was basically built from Max's 2.8 build. They simply had a damn good idea and ran with it. It was initially a project for the 2.8 that turned kit, using the 2.8 manifolds. If wanting to do forged internals to the 2.8, might as well get boost friendly pistons. The pistons is what makes the 2.8 not FI freindly. You need a lower compression ratio piston.
    Feb 28 2005
    Tempe
    If only..
    ....they used the Vr6 instead.
    Good greif think of the built cars we'd have.
    Dec 05 2007
    I'd have one. Not a fan of the 2.7t, even though I do acknowledge it as a great engine. But I would probably have a 1.8t BT as a dd and the vr6 BT as a weekend warrior.
    Feb 28 2005
    Tempe
    Yep, spot on. The only way I'd consider a 2.7t ever, is if it had a solid worked out flawless "above/behind the cylinder heads single turbo system". Pulling the motor and trans is hogwash, guys have had to pull their entire perfect working setup motor and all......all because a single ~10mm nut backs out on a single waste gate of one turbo. All that, for a 30 second tightening job. Now the smart thing is to safety wire the the nuts (of has been), but those motors eat turbos.
    To do it once that's cool, clean everything up, do it once, check everything out....but again and again...nawh.
    Mar 01 2016
    Houston
    I'm not opposed to this option. But I would like to keep the 2.8 and do forged internals either way at this point. Can't say that will never change but I've already got some parts on the way...
    Quote Originally Posted by a4kamila6 View Post
    Definitely going boosted and forged. But like I said, I'm not opposed to a big single, possibly duals...
    Man if someone was, that may make my decision to go to turbo much easier...
    Definitely getting forged internals... As a matter of fact, rods are on the way.
    Is there a link to any of this info? I'm ready to gain some knowledge...
    Mar 01 2016
    Houston
    Did some more diggin... Seems the SC option will be a no go at this point. https://store.034motorsport.com/034m...turbo-kit.html
    Does anyone here have a good contact for 034 that I can bug with some questions??
    Also, I assume this will work on a 2.8 if I run a 2.7 intake correct?
    Dec 10 2013
    Borden, Ontario, Canada
    Yup. Are you still planning on only doing rods? Because the cast pistons will explode well before the rods go lol
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Mar 01 2016
    Houston
    Quote Originally Posted by Bordom View Post
    Oh no! I plan on pistons as well. Cams and oversized valves as well. Thats the stuff I'm needing info on. Such as if the 2.7 pistons are the same as the 2.8 and so on...
    Dec 10 2013
    2.8 bores are 82.5mm vs the 81mm of the 2.7. Many dudes overbore to 82.5mm and use those oversized pistons which are compatible with the 2.8.
    If I were you, (and I will be doing this in a few years), get yourself at least a 3 angle valve job on the intake and exhaust, port out the intake trumpets on the 2.7 intake and enlarge the runners, then take your 2.8 cams and have them reground to a moderately more aggressive profile.
    You're pretty much set afterwards and add in your supporting mods.
    For the trans, if you're going to have it rebuilt, drop in a TDI 5th while you're at it
    IG: 24_et
    Sold:
    RIP:
    Mar 01 2016
    Houston
    Awesome bud! Thats some of the info I'm lookin for! I'm going to order the 034 rear diff mount this week, so I'm going to start talking to them about sourcing some of the internals as well as the big single turbo kit. Thats the route I've decided to go, something about a turbo... lol.
    On another note, trying to buy my wife an STI in the next week or two so after getting the parts I need now I will have to save for a few weeks to get a good chunk towards the Suby
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Apr 25 2013
    Centennial, CO
    So I know this thread is discussing a V6 setup. I'm looking to run an eliminator 2871r on a 2000 a4 w/ ATW motor with some kind of tune. Anyone have experience or know a user running this setup? Looking for some advice/guidance.
