Results 1 to 6 of 6
    Established Member Two Rings //AudiB's Avatar
    Oct 14 2015
    Georgia, USA
    2012 B8 A4 S-Line to aftermarket Shocks/Springs Thoughts and Opinions. Decisions...
    Right now ECS Tuning has H&R springs and Koni Shocks on sale so I might just be pulling the trigger on a setup... I have a 2012 A4 (B8) w/ 55,000 miles on factory suspension. I'm not sure if i have the S-Line suspension or sport. I have S-Line badging, 3 spoke steering wheel but my car is the premium plus package which i have read only comes with sports suspensions is this correct?
    Koni FSD Sale
    Koni Sport Sale
    H&R Sport Sale
    H&R Super Sport Sale
    Between the following which would you recommend:
    1. Koni Sport Yellows w/ H&R Sport Springs ($764.80) My current choice
    2. Koni Sport Yellows w/ H&R Super Sport Springs ($754.80)
    -or-
    3. Koni FSD w/ H&R Sport Springs ($956.95)
    4. Koni FSD w/ H&R Super Sport Springs ($946.95)
    -or-
    5. Factory shocks w/ H&R Sport Springs
    I wish I could afford coilovers right now but because of the sale and pricing I'm leaning more towards the Koni Sport Yellows which are adjustable off the car.
    I figured also the Yellows would be better when going to aftermarket lowering springs.
    Keep in mind later down the line I would like to upgrade to an Accuair Suspension which would be used with the shocks I get with this setup.
    *EDIT* - Tire Rack is apparently having a Koni sale as well from 03/01/2016 - 09/05/2016
    Tire Rack Sale - Koni Sport Yellow w/ H&R Sport Springs 'KIT' - ($625)
    Veteran Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    I've had my oem S Line sport shocks w H&R Sorts since early 2010/ >100k and haven't had any issues.
    That said, I may jump on a set of Koni shocks to replace given their age.
    Otherwise, handles fine w minimal degradation in overall performance/drive comfort
    Oct 14 2015
    Georgia, USA
    if you did get Koni shocks would you get the FSD over the Sport yellows? I wonder what the comparison would be between our stock sport shocks and the FSD?
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    If you post a picture of the car from the side we can probably tell which suspension setup you have. If your budget is a grand or more and you ultimately want coilovers, you can get Solo Werks coilovers and have them installed for that price... The whole deal (minus alignment, which you need either way) would cost roughly what that most expensive set of shocks and springs is going for.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Veteran Member Three Rings Acme's Avatar
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    If I can chime in and give you my feelings on Koni FSD vs yellow... I can't compare 1:1 between sport S-Line and non-ADS and Koni Yellows and FSDs though. But I previously had a B7 (2008) with FSD + Eibach Pro kit and really liked it. The ride was still comfortable and the car felt like it was on rails. Some people feel they are a bit bouncy because the rebound isn't as restrictive as it should be (maybe) and it isn't adjustable. But... it never bothered me. And my driving style is pretty aggressive/sporty. Maybe Yellows are better in this respect, but from my readings at the time, they are also stiffer. It really depends on the roads where you live, and the ride you want. Here our roads are real crap so the FSDs were a good compromise between performance and ride comfort.
    BTW, you can have a look at options for you car here: http://n4te.com/s5/docs/2012%20Order...A%20Retail.pdf
    From that list of options I would say that if you have a 3-spokes steering wheel, you probably have the sport package, which included the sport suspension. Check the sticker in the trunk (near the spare tire) and see if you have the WQS option listed.
    2013 Daytona Gray A4 Premium S-Line Quattro 6MT - NAV - bi-xenon - adaptive dampers - Alcantara - Eron's rear view cam
    SOLD! 2008 A4 2.0T Quattro 6MT Unitronic stage 2
    Jan 19 2016
    1997 BMW M3 w/ CES Stage IV Turbo, 1999 BMW M3 vert
    Orlando, FL
    Also, the coilovers are great if you make adjustments, but I've had coilovers on my M3 since 2005 and have never adjusted them.....I have a nice eibach spring/bilstein shock setup on my '91 e30 and love it....
    If you aren't tracking the car, then coilovers are pretty much for adding to your stat sheet at the bottom....save your money.
    1997 BMW M3
    CES Stage IV (651rwhp/615rwtq @ 24 psi)
    2020 S6
    Premium Plus, Black optic, performance exhaust
    2013 Audi A4 (sold)
    Prestige package, S-Line, 6-speed |IE Stage 2 | IE Performance Downpipe | S4 exhaust swap | ECS Luft-Technik intake | ECS Luft-Technik FMIC | RS4 grille | ECS SSK | ECS Trans/Diff Inserts |
