Results 1 to 17 of 17
    Established Member Two Rings Jg3's Avatar
    Jun 11 2015
    2005 A4 B6 3.0 cabriolet
    SGV
    Question Turbo too hot? Loss of hp A4 B8 Quattro Sline
    Hi guys I'm kinda new, my first post hoping to get help. I have a 2012 A4 B8 Quattro, 120k miles,APR stage 1, Injen cold air intake, Billy boat double dual exhaust. I'm having a issue with loss of performance. At around 3000rpm my car used to take off real good but now it doesn't and I get a sound like blowing air out and whistling and not much power. This started after the hose on my recirculation bov came off and I had to continue driving that way like 20 miles home. When I got home I noticed a good amount of oil had came out of disconnected hose connecting from boost tap to bov. After I put new hose I've had this problem and I think my turbo is getting hotter too. Can anyone help with this?
    Jun 26 2009
    Bremerton WA
    Any codes. Without the blowoff valve operating you may have had an intake system overpressure and a charge hose blow off or damage to the intercooler. A good visual inspection (maybe pull the bumper cover off) followed by a boost leak test.
    VMR 710's, APR software, Eurocode HFC
    Jun 11 2015
    SGV
    No codes
    Jun 11 2015
    SGV
    How do I do a boost leak test?
    Jun 26 2009
    Bremerton WA
    http://www.audizine.com/forum/showth...t-leak-testing Here is one I put together a while ago. I wrote to used the least amount of special tools. But an air compressor or tank set to 5 psi really helps
    Sep 01 2012
    Edmonton
    My guess would be a leaky DV and there might be a soft code not being shown. IE the P3 guage wont detect certain codes. Also check all clamps on intake system for loose leaks.
    2018 RS3 Panther Black
    Jun 11 2015
    SGV
    Will do thanks
    Sep 01 2012
    Edmonton
    Good luck, keep everyone posted to help out other forum members who might encounter this problem.
    Jun 11 2015
    SGV
    I will lyk thanks
    Jun 11 2015
    SGV
    Quote Originally Posted by Jg3 View Post
    Jun 11 2015
    SGV
    Ok after going more research I found out I have the ticking sound while coasting. Sounds like another user said "a plastic fork in a fan" which I understood means bad wastegate . Do you think this might be my problem as well?
    May 31 2015
    Philadelphia, Pa
    For about 5 months, I have been dealing with this "ticking sound while coasting" issue. Its your wastegate rattling against ur exhaust housing of the turbo. If the wastegate play is mild, you can purchase a wastegate rattle clip to stop further damage. Installing the clip for Audi (atleast the longitudinally mounted engines) involves removing the cat to gain access to the wastgate. The only real fix is replacing the entire turbo since the exhaust housing/exhaust manifold and wastegate is all one piece, and a turbo rebuild is not an option. There are multiple threads on this issue so you can look back. I remember one guy shortening the arm of his wastegate actually to get rid of the excessive play. I ultimatley had to replace my turbo out of pocket through Audi ( out of warranty) because the car started driving like a NA car, producing no boost at all. I have the same question about why my obd didnt trip a check engine light even though I wasnt producing boost. Hopefully this helps.
    Jun 26 2009
    Bremerton WA
    Oddly enough I have a DIY on that as well. While I did the repair in the DIY a few years ago, it is still holding up. New turbo is the best option but read over it, it does go in how to diagnose a bad wastegate without any disassembly. Pulling the cat back for a visual is better, but if the wastegate rod is moving it isn't sealed. http://www.audizine.com/forum/showth...lapper-(P0299)
    May 31 2015
    Philadelphia, Pa
    Yeah, your DIY will most likely be useful for several more years. Lol this isnt just a Audi issue, it an issue that plagues all turboes throughout multiple auto companies. I know a bmw owner that went through the same thing, unfortanetly for him he had to replace both of his turbo being twin turbo. But anyway, ur diy most most likely be adaptable to help future B9 and current Q3 and Q5 owners.
    Jun 26 2009
    Bremerton WA
    The big downside is the early IHI K03's had issues with the bushing that the wastegate arm goes thru the turbo housing. It elongates and then the wastegate actuator has no adjuster to take up this slop. On top of that once the bushing elongates, the wastegate doesn't move in quite the same arc and can have seating issues. I have been tempted to grind the weld off the actuator arm and rebush the turbo but i don't have lathe access to machine to fit a bushing. Its possible a standard size would fit but that's a fair amount of labor to go thru. As with a lot of things DIY it depends on how you value your free
    time and how much you like to tinker with stuff.
    Jun 11 2015
    SGV
    Thanks for the help. I was lucky to find a ko3 turbo on offer up. Before I have it installed is there any advice or recommendations as too what I'll be needing? Any special tools, parts etc.?
    May 31 2015
    Philadelphia, Pa
    Hex bolt and triple square bolt sets are required. I would also recommend different socket extention sizes, universal socket joints ( more than one), flexible socket extension (mainly to get at the coolant and oil feed and return lines), and lots of patience. The gaskets and o rings can be brought from Audi for about $70 bucks.
