    Jan 04 2016
    1967 Ford Mustang Coupe 289 w/ 3 on the floor
    Boston, MA
    No breather hose?
    Hey guys, just installed the CTS intake and my factory air box did not have a breather hose attached to it...? There was no possible way anything remotely close to a breather hose could attach to the air box, only a weird looking butterfly valve on the side of the airbox closest to the engine. Strange or common? Any input from anyone on this?
    Veteran Member Three Rings carlosvjr92's Avatar
    Nov 25 2015
    Miami, FL
    Like this? This is where mine was connected. Maybe yours got disconnected somehow before or during install
    2018 RS3 (Cumulus Blue) - APR Stage 2 || APR Intake || APR Downpipe
    Jan 04 2016
    Boston, MA
    Ah ha! Interesting... Gonna have to fish around and find it haha. Good looks brah!
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    That butterfly valve is a secondary intake in case your snow screen clogs with snow, it will draw air from the engine bay which will be warm enough to not have snow/ice clog it up. You'll see its designed to open if the air box gets too much vacuum. It works in conjunction with the snow screen to prevent a build up of snow/ice in the air box. Other things can clog it too, a few good-sized leafs or a bunch of pine needles can also clog up the intake at the snow screen. So, in the event of that happening, there is a secondary intake.
    A true CAI (one that draws air from the lowest point possible in the engine bay) will often have a relief mechanism somewhere up near the highest point of the intake system for similar reasons. Those CAI's on a street vehicle also have to deal with the possibility that the intake could become momentarily submerged, though in those situations the relief valve is there to break the vacuum and not suck water directly into the engine.
    Your secondary air pump intake should be a hose that was connected to the air box. If you look in the air box as it was installed, on the left-had side there should be a foam looking thingy, which is the filter for the secondary air intake pump hose. The hose would be connected directly beneath it.
    Edit: didn't feel my answer was good enough, so added more info about different intake systems.
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    @amz: Nice info and explanation!
