Results 1 to 19 of 19
Thread: Stage 2
    Senior Member Three Rings Gmoney1147's Avatar
    Dec 09 2014
    Roseville California
    Stage 2
    What all do I need to do to go stage 2 anyone know? Sorry for dumb question.
    Established Member Two Rings Snowboardguy989's Avatar
    Feb 02 2011
    F350 Dually, Volvo xc90 V8
    OKC
    Google what tune you want it will be on their website.
    Realize that any neglected maintenance or issues will need to be sorted before putting more power down. Best of luck.
    Also try the search bar.
    Sent from my SM-G920P using Tapatalk
    -JHM stage 2 - Borla exhaust - 034 RSB - ST coils w/ hyperco springs - JHM Stage 2 clutch - 034 motor & trans mounts - JHM extra short shifter - APR HPFP-
    - TP - evolution thord skidplate - Devils own W/M - more stuff -
    hood RACECAR™ spec-rear diff mount
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    You're not sorry at all lol
    - We have an entire thread specifically dedicated for "dumb questions". You could have asked this in there
    - you never stated what tune you want
    - every OTS tuner has a website, and in that website they have all the prerequisites listed
    If you're gonna be lazy, at least do it right lol
    2008 A4 S-line 2.0T
    JHM Stage 2
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    stage 2 doesn't mean nothing. You have to add a brand.
    Feb 15 2016
    Cambridge,Ontario
    wow i guess i'm even lazier than him . I was wondering the same question , i just waited till he asked it .. :0
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    He's been on the forum for 2 years. You haven't
    2008 A4 S-line 2.0T
    JHM Stage 2
    Active Member Two Rings root_to_the_a4's Avatar
    Jan 20 2016
    B8 Q7
    Woodstock, VT
    A few brands include APR, ECU, Unitronic, Giac, Revo and many more but those are some of the most popular. I am planning on going Unitronic Stage 1+ which includes upgrading the diverter valve and intake, which I am going Carbonio. I also am adding a downpipe and AWE exhaust to ensure that I get the most out of the tune until I upgrade to Stage 2. When tuning any vehicle there will be other components that will need to be upgraded. For a stage 2 typically this includes a downpipe, exhaust, cold air intake, intercooler and usually the diverter valve (B7 diverter valves have a tendency of breaking internally and would suggest the upgraded on on ECS)
    Jun 26 2015
    2008 Subaru Tribeca
    Lancaster, PA 17603
    Your lack of details to help us help you and the lack of effort to research disturbs me. Stage two isn't cheap and is not something you just willy nilly drop in the B7 and zoom off. Take some ownership of it.
    Took me 30 secs to find three different views on stage 2:
    http://www.audizine.com/forum/showth...oftware-Review
    This gentleman's mod list for stage +2 is costly:
    http://www.audizine.com/forum/showth...sports-stage-1
    United MOTORSPORT Stage 1 tune
    Integrated Engineering 144x20 Connecting Rods
    JE pistons 83mm w/ 9.5:1 Compression ratio
    AWE Front Mount Intercooler
    APR High Pressure Fuel Pump
    HPFPupgrade 145lbs. Pressure Rail Valve
    034 High Flow Cat
    Stasis Cat back exhaust
    Integrated Engineering Ultimate Rod install kit
    Calico rod bearings
    ARP Head Studs
    ARP Main Studs
    ARP Tower bolts
    Integrated Engineering Dowel pin Kit
    Fluidampr
    JHM 4:1 Center Differential
    DRAKE'S PERFORMANCE stage III clutch
    Clutch Masters flywheel FW-025-SF
    USP Metal Slave with Stainless steel line
    Apikol Snub Mount
    Apikol Transmission Mount
    Apikol Rear differential Mount
    034 Street density engine Mounts
    034 Turbo Inlet Hose
    RAI Catch Can
    http://www.audizine.com/forum/showth...ECOMMENDATIONS
    Also, here is the build/project threads for a ton of inspiration. I bet you that 99% of the people in this section of the forum are tuned/planning to get tuned/or are in the same boat as you but researching it in the correct part of the forum:
    http://www.audizine.com/forum/forumd...cts-amp-Builds
    Grab a beer and start reading. Cheers
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by spennyb7 View Post
    034 High Flow Cat
    Calico rod bearings
    ARP Head Studs
    ARP Main Studs
    ARP Tower bolts
    Fluidampr
    Apikol Snub Mount
    RAI Catch Can
    Stage 1 tune with an upgraded HPFP? Sounds like someone isn't done.
    -Adam
    Jun 26 2015
    2008 Subaru Tribeca
    Lancaster, PA 17603
    Stage 2
    If you look at that thread, he is asking about going to stg 2, which is why it is relevant to the OP.
    Mar 24 2013
    Oakdale, CT
    Your right, I didn't actually click on it. That's Carl's car and it doesn't really put anything in perspective for the OP because most of that stuff is not required for what is commonly referred to as stage 2. You need the tune and a HFC/test pipe and that's pretty much it. Stage 2+ adds an upgraded HPFP and (if you're smart) an upgraded rail valve. Other upgrades beyond those will obviously help, but aren't strictly required.
    -Adam
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Gmoney1147 View Post
    Ahh come on Gmoney........You know better then that....Gmoney knows "Quotes from New Jack City"
    Dec 09 2014
    Screw Jhm lol
    Dec 09 2014
    So first off I used the search bar. Second I'm just talking flat stage 2 not stage 2+. I was just asking in general. I have a normal stage 1 tune that's custom but very similar to all companies.
    Apr 12 2015
    '06 VW TOUAREG (V8), MTN Bike
    FALLON, NV
    "upgraded rail valve". Didn't actually know what this is for until I hit the search button. 145 bar for S2+ and 155 bar for S3/BT sound about right? Looking to upgrade my HPFP in preparation for JHM's S2+ 93 OCT tune....
    I'M THE ORIGINAL OWNER OF '07 B7 A4 2.0T 6MT Q (62K): JHM 91 OCT STG 2 | CARBONIO INTAKE | 034 REAR SB | JHM TP | JHM DP-Y | B6 S4 CB
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by MISKIE View Post
    It all depends on what rail pressure the tune is running. HPFPupgrade recommends a rail valve set at 10 bar above your max rail pressure, although I think you would probably be ok with 5 bar above.
    -Adam
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    I don't think jhm's tune plays nice with an upgraded rail valve unless stage 3. I think jimrobbington had issues with their tune with one. Check with jhm first.
    Apr 12 2015
    FALLON, NV
    Quote Originally Posted by onedumslack View Post
    Thank you both! I'm still thinking/researching before I upgrade. As you know, the west doesn't have 93!
    And I Still need to take care of some preventative maintenance first.
    I will ask both Jim and Jake though...
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    I remember when i was with APR 2+, I was meeting requested numbers and the rail valve wasn't necessary for me, meanwhile others needed it. Now with JHM i haven't done any logs to see.
    Tbh, Im not entirely sure why others needed it and some didn't
    2008 A4 S-line 2.0T
    JHM Stage 2
