So i've read multiple things. Baby it till like 1k, romp on it for the first 200 miles, etc.
the most consistent i've seen is:
Fill with 5-40 non detergent oil or rotella t6.
start engine and run it for 30 mins.
drain oil and swap filters.
refill oil along with lucas engine break in (more nickle) and go out on the road.
within the first 200 miles do 2nd-4th gear pulls from roughly half rpm to just before redline at WOT and then let it decel in gear.
replace oil again after about 200 miles.
Let me know what most of you with rebuilds have done.
ALSO what worries me is that im running a brand new turbo and RA4 clutch with single mass flywheel. I know for a fact that clutch break in requires light driving. Dont want to tear up my clutch and flywheel trying to do WOT runs in a non tuned big turbo you know?
current setup:
GTX2867R
IE Rods 19MM pins
034 fuel rail
1000cc bosch injectors
AEB head + mani
3" billet MAF
Garrett 600HP core
TiAL QV BOV with recirc to intake
Currently on a stage 1+ tune
Deatsch werks DW65V fuel pump will be installed once i use up some fuel (made a custom bracket to house it)
proper tune to come after motor is broken in
