Results 1 to 7 of 7
    Jan 15 2014
    Denver
    04 A4 3.0L quattro.Car won't start.
    I can't seem to find out the problem on why my car is not starting. It turns over but won't start. I have changed the spark plugs and ignition coils but still no luck. Could it be a bad icm? Any tips would help,thanks.
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    Cranking is a good start - that means timing and cam/crank position sensors are ok. Check that there is actually spark by inserting a spark plug into the coil. Ground the base against something metal on the engine while cranking. Confirm spark. If that's good, move on to fuel. Turn key to on, and listen for the fuel pump priming. If it does not prime, check fuel pump relay. If it primes, and still will not start, replace fuel filter.
    One of those should get you going.
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Jan 15 2014
    Denver
    I have changed the fuel filter last year so I don't think that's the problem. where would the fuel pump relay be?
    Sent from my SM-G925V using Audizine mobile app
    Jan 15 2014
    Denver
    Quote Originally Posted by cschuster View Post
    I have changed the fuel filter last year so I don't think that is the problem. where would the fuel pump relay be?
    Jan 15 2014
    Denver
    Also, note that I have changed the pcv also(crankcase breather valve ). Before my car stopped running, I was at the park still in my car, turned off the engine and when I tried to start it again it wouldn't start. Had it towed home,opened the hood and saw that the old pcv valve had been broken or blew up.
    Established Member Two Rings a4cruiser's Avatar
    Feb 03 2009
    99 gsx600
    St. Louis
    Any check engine lights or new lights on the dash? Codes?
    If it isn't broke, don't fix it... EDIT. It will be broke soon.
    3.0 Group Member
    Jan 15 2014
    Denver
    Quote Originally Posted by a4cruiser View Post
    I don't have anything to test the codes. the check engine light will come on sometimes and then go away now that you mention it. Also, the abs sensor will come on sometimes and the speedometer would stay at 0mph,but I know that I need a new abs sensor.
