Results 1 to 11 of 11
    Sep 24 2014
    Long Island, NY
    How do I keep doors locked/kid-friendly when driving??
    Ok so I have a little unanticipated problem. My toddler opened the door (from a car seat of course) when we were driving. Obviously that was pretty scary. So I figured ok no big deal, let me just make sure that the door is on "locked" all the time (with the red light on). Guess what - he opened it again while it was presumably locked! Is this normal? Is there a way to make sure that all doors are locked when it motion and can only be unlocked by the driver? I hope so... What am I doing wrong?
    Thank you!
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Child lock.. Its on the door hinge..
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Sep 24 2014
    Long Island, NY
    Right, so I press "lock" on the driver's door, which is what I assume is what it is, it does turn on red and STILL all others doors can be opened by pulling on the thing when I am driving. Does that mean something is off with electronics?
    Aug 03 2014
    Queens
    No it's nothing electrical actually.
    When you open the back door, on the lock hinge there is a little hidden key insert.
    Previous
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    On the side of the door (when opened) turn the child lock switch using the car key (metal key).
    FYI this exist on every four door car I've ever encountered made within the last 20yrs.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Quote Originally Posted by Slav4ikMD View Post
    Wrong. Page 41.
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    the rear doors have child locks on them
    open the rear doors , look at the edge below the latching mechanism . the is a round cut out , with a slotted insert. You turn the insert with a screw driver, and the door can not be open from the inside. It can only be opened from the outside if is not locked byhe power door locks. But kids can not open the door from inside if yo have set it up
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Sep 24 2014
    Long Island, NY
    Aha! Awesome, thank you! Maybe I should read the manual one day :) lol
    Since we've had the kid, the only other car experience was with my wife's Acura MDX and there you just lock with the lock button on the driver's door and that's it. I am surprised it has to be done manually like that. But fine, this is good to know! Will do that.
    Veteran Member Four Rings Race Shooter's Avatar
    Dec 22 2006
    Raleigh
    RTFM.
    The fact you can open the doors while "locked" is a safety feature. Its a mechanical lock release in the case of electronic failure. You pull once and it unlocks the door, pull it a second time and it will open the door.
    Your Acura probably had an actual mechanical switch that could be used to unlock the door without using the electronic button (thats how my parents TSX is. There is nothing like that on the Audi, which is why they use the door handle.
    Your Acura has the same child lock feature on it, because, as someone said, just about every car for 20 years has had this feature, you just probably never used it since your kid didnt know how to unlock the door. Pulling a door handle is a lot easier.
    2014 Porsche Cayman S Guards Red
    2015 Sepang Blue S4 6MT Gone...easily forgotten.
    2004 Nogaro Blue S4 Avant 6MT Gone...but severly missed .
    Jim Sykes Photography motorsports photography
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by blackfunk View Post
    Also, if you're like me and I like them engaged at all times, even with tween's in the house who are smart to figure it out, I put a small piece of electrical tape over mine that I cut into a circle about the size of quarter and covered it up.
    The reason being is my son who hates that I have them engaged will be a smart butt now and then and disengage it. Now it's harder to do and honestly he doesn't even know where the switch is as he hasn't put it together with the fact that I covered it up
    Not only is it safer for the kids, but it saves me from having one of them opening the door into another car.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
