Results 1 to 33 of 33
    Aug 07 2011
    Montreal
    Rock chips look terrible behind RS4 grille!
    So, last summer I swapped out my grille for the B8.5 RS4 one that most of us have and before I installed it, I painted the aluminum bar black behind the bumper since I knew it would stand out and look bad seeing a shiny aluminum piece of metal behind the black RS4 grille. Now, after a relatively mild winter, I'm pretty bummed out seeing all the road chips that have have chipped away the paint on the bar. It looks terrible and wanted to know if any of you had the same issues and what options some of you might have done to reduce the chipping. Did I use the wrong paint or is there something else that could have been done without ruining the overall look.
    Thanks again
    15' S4
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    I'd try using black bedliner or rocker panel spray, it's meant to take the abuse. Curious if you primer or prepped it in any way first or just started spraying.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Don't sweat it. Mine has done the same thing and I kind figured it would. I scuffed, primed and painted it hoping..... I'm going to fix it in the next couple weeks by using some bed liner spray. Just be sure to mask off the front end well, and of course the sensor for the temp and homelink too.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Aug 07 2011
    Montreal
    Quote Originally Posted by MacFady View Post
    I primed it and then sprayed it flat black. Nothing professional, just me doing it.
    15' S4
    Established Member Two Rings Woodybangs's Avatar
    Jan 08 2016
    MI
    Use black vinyl. No rock chips.
    Aug 12 2013
    Lexington KY
    I used a bedliner product the first time I did mine. After about 3-4 months it began chipping as well. I then pulled it all back apart, stripped the old paint and prepped the bar really well but only using alcohol swabs. For the second run, I used plastidip and just put about five coats on.
    It's held up pretty well. I think its all in the prep and throw on as many coats as you can.
    Best of luck.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Are the bed liner products like flex seal?
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Dec 10 2012
    New York
    I vinyl wrapped mine. Not a chip to be had.
    Jan 07 2011
    2013 C300 4Matic
    plastidip works for me. no chips.
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Feb 20 2006
    NC
    I haven't installed my grill, but it came with a thin plastic to put over the aluminum bar.
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by switchedstance View Post
    Link to product used?
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Instead of paint, I got a sheet of black HDPE from Menards and cut it to fit. I didn't like the contours of the crash bar showing through paint/plastidip. The sheet was ~$12 and I've still got plenty left over in case it ever needs replacing.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    I used bedliner and it's been 8 months and no chips with lots of highway mile. I wiped down the crash bar with alcohol prior to painting and the bedliner I used was a primer and paint in one. However, it does need about 8 hours to completely.
    2016 S6
    Jan 10 2007
    VA
    Vinyl wrap > Plastidip > Paint
    Jul 10 2015
    Quote Originally Posted by scottycs View Post
    Yea but the plastic is shiny and looks terrible imo, best to leave that off.
    My crash bar had already been plastidipped twice from rock chips.
    Sent from my VS985 4G using Tapatalk
    Aug 07 2011
    Montreal
    Great help! Thanks to all.
    15' S4
    Nov 20 2014
    New York
    Well what I did was I took the plate delete cover because it already had holes in it, made two holes on the corners and zip tied it to the crash bar and plasti dipped that black with a few coats, but I have a b8. U can probably source a b8 plate cover too. No more chips and it hides the crash bar. Looks very oem like
    Feb 20 2006
    NC
    Maybe I will try spraying it with plastidip.
    Quote Originally Posted by bizzy View Post
    2021 BMW M340i
    Jul 10 2015
    Yea that could work. I originally had mine on but removed it because it protrudes pretty far forward too, which makes it more visible from the front. YMMV.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by b6onboost View Post
    Really? Vinyl wrap still gets punctured with rock chips. I have had mine plasti dipped for close to 60K now and it looks great still.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings ENV²'s Avatar
    Nov 04 2010
    I used plastidip when I put the grill on my S4. In 4 years it never chipped.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Nov 30 2010
    Anchorage, AK
    Quote Originally Posted by jl87 View Post
    Looks great, and a great solution - I think I'll go this route when I order mine.
    2010 Meteor Gray Prestige //S4 DSG
    Senior Member Three Rings Powderhound's Avatar
    May 09 2015
    CT/VT
    Same here, dip holding up fine so far.
    2013 S5 Prestige | Phantom Black | Black Nappa | DSG | Sport Diff | Carbon Atlas
    Mods: Full Xpel, Ceramic Pro, RS Grill, Deval CF lip & diffuser, ECS CF side mirrors, Ecodes, EPL stage 1 ECU & TCU, H&R Street CO, SPC UCA, AWE S-FLO CF Intake, AWE Track/Res. DP, Alu-Kreuz, CR-15, Stoptech slotted rotors, stainless brake lines, 034 engine and trans. mounts, Vorsteiner V-FF 103/Conti DWS 06/H&R DR 5f 10r, Winter: Peelers/Nokian Hakka R3/H&R DRA 20f 25r/WeatherTech
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    This is a no brainer - Use plastidip.
    Senior Member Three Rings Dasaudi mtl's Avatar
    Dec 04 2012
    Montreal & Florida
    plastidip as well the way to go
    2018 SQ5 Black
    Veteran Member Three Rings jamesj2k's Avatar
    Feb 17 2008
    Ashland, KY
    I used plastic dip. 4 coats. Rocks chips galore after 1 year. Vinyl wrap if the way to go. The rock hit the vinyl and will only make a small mark instead if a "chip".
    Established Member Two Rings cw8307's Avatar
    Feb 10 2012
    2013 Audi S4, 2013 Nissan Pathfinder
    Boiling Springs PA
    Plasti dip it. Rocks bounce off rubber. Survived on my Harley for 3 years before I sold it and it still looked new.
    Feb 10 2012
    Boiling Springs PA
    Just don't be inpatient. 1 light, very light, coat and 5 additional coats. If unsure go on YouTube and look at plasti dip harley and you'll see my videos. I'm using plasti dip.
    Feb 17 2008
    Ashland, KY
    Heck..how about matte vinyl wrap and plasti dip over it! I've had my fair share of removing Audi front bumpers...don't want to make a habit of it!
    Aug 12 2013
    Lexington KY
    Plastidip that bad boy. It's all in the prep. Wipe bar down w alcohol and then multiple coats. Just take your time.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    This is what I used after I searched and did mine. I have 0 chips and any local auto parts store has the pastidip
    Oct 14 2012
    Empty...for now...
    SE PA
    This looks great, and in fact looks a lot like the OEM solution on the RS models. Where did you attach the hdpe sheet to the car, and what did you use to attach it? I don't see any screws going through the front.
    SOLD 2015 Daytona Gray S4
    Jul 25 2010
    WI/IL
    Quote Originally Posted by SteveYem View Post
    I cut the sheet so that it had about an inch overlap above/below the crash bar. I also made sure it extended far enough to the sides that it would be behind the bumper when mounted, that is why you can't see screws. I also painted the crash bar black before attaching the HDPE so that you couldn't see silver when looking at it from above. Feel free to ask if you've got any more questions.
