Results 1 to 6 of 6
    Active Member Two Rings B5AvantTurbro's Avatar
    Oct 28 2015
    '71 Plymouth Road Runner 383M
    Eagan, MN USA
    Question AEB parts laying around? PM me.
    It's time for an AEB build for my 99.5 A4 B5 1.8T Quattro Tiptronic Avant Volcano Blk.
    Starting from scratch, everything is needed. Any AEB compatible parts will be considered.
    Interested in engine parts you may have laying around from previous builds or part outs.
    058 block wanted
    AEB head wanted
    Crankshaft for Tip
    Cams ect.
    Veteran Member Three Rings bikerbob951's Avatar
    Jul 25 2008
    2006 Volvo XC70 AWD, 1936 Dodge D2 Touring Sedan
    Cincinnati, OH
    I've got an intake manifold and a valve cover, both AEB. You want?
    Vorsprung Durch Technik.
    1999 AEB B5 A4 quattro
    My new build thread. Instagram
    Active Member Two Rings boostinavants's Avatar
    Jan 24 2010
    98 a4 avant workhorse
    walnutport
    I have a good amount of parts and some new OEM stuff. BNiB oil pump, gaskets, sensors, etc. let me know what all you might be looking for
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    have you considered swapping to a manual? if you are building the car for any kind of power, Tiptronic go BOOM!
    as for the parts you are looking for, i do have a bare AEB head ready to be built
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Oct 28 2015
    Eagan, MN USA
    Quote Originally Posted by GrapeBandit View Post
    Gonna do a decaf build on the aeb tip. And im picking up a 00' 5speed avant to do a real nice aeb build. Because money CAN buy happiness. Why not both? *salsa dance*
    Sent from my 710C using Tapatalk
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    I have an AEB block that's been bored to 83mm. It actually needs to be bored to 83.5mm (max for this block) as it was bored too big for the pistons and rings I purchased. It's been oiled and sealed for storage for a few years. All of the journals and internal structure is good.
    make an offer, you cover shipping. Located in Kansas city, MO
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
