Results 1 to 7 of 7
Thread: What is this??
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    What is this??
    Changing rear shocks and noticed this. What does it do? Why is there a filter?
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Dec 19 2011
    Colorado Springs
    Looks like something for the fuel vapors from the tank...but Im also interested as Im not certain.. Almost looks like it should be shielded or covered.
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    That is the leak detection filter. ECShttps://www.ecstuning.com/b-genuine-...ter/8d0906321/. Not sure if there's a cover on it....don't remember seeing that when installing coilovers, although I left the wheel liner in. It probably just sits behind there.
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Dec 19 2011
    Colorado Springs
    Quote Originally Posted by cschuster View Post
    Any suggestion on replacement intervals? or possible MPG gains of changing it?
    Jun 05 2013
    Lexington, KY
    Nope and nope. Plenty of better places to spend $$ on.
    Sent from my Nexus 5 using Tapatalk
    2011 TTS
    Dec 19 2011
    Colorado Springs
    Cheers! Good info regardless!
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The filter is connected to the LDP. It's purpose is to filter the air that gets sucked through the charcoal canister when the N80 Evap control valve opens to purge the canister of the accumulated hydrocarbon vapors. It will not have any effect on your gas mileage. If it gets clogged up the N80 will no longer be able to purge the canister and you will get a CEL for incorrect flow through the Evap purge cycle.
