Results 1 to 7 of 7
    Oct 27 2015
    NorCal
    Americas Tire didn't want to install my tires. Went elsewhere
    I figured Americas Tire would be weird about installing my 225/40/18 tires on my 18x9.5 wheel. I had to try but it was a waste of my 8 minutes. Then I made an acquaintance with a dude at Firestone who is running a 205/40/18 on the same size wheel and he would install it but would have to charge me Firestone pricing at a total of $167.00. Someone is smoking crack today. I called around in the West Sacramento area and had everything done for $40 out the door. He said the 225 was a piece of cake and I watched them tackle it. He said he did a 205/40 on a 10 wide wheel and that was work, mine was nothing. Kudos to The tire shop. Sorry no pics. But they are Nitto NeoGen on Privat Kups.
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    You wouldn't have these problems if you ran proper tires for your rims.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by martin0079 View Post
    Lolz, but true. I run a 225 on an 8.5" wheel and thats as narrow as I was willing to go.
    -Adam
    Oct 27 2015
    NorCal
    [QUOTE=martin0079;11445016]You wouldn't have these problems if you ran proper tires for your rims.[/QUOT
    True but the 215 wheel fits the same on the 8.5 (which is within spec according to Nitto) as does the 225 on the 9.5. I've seen people pull of a 235/40/18 with a 18x9.5 in the rear but it cuts it close when lowered so I guess I had to be different and deal with the answer No. Won't be the first time.
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    I run 235/35/19 on my 19x9.5 wheels and I wouldn't run anything less than that, I have no problems running that on my ST coils around 24" ftg without adjustable control arms. 225 on a 9.5 wheel is pretty damn risky IMO, good luck with keeping the tire bead.
    Thanks for the EFF shack. -Dirty Mike and the Boyz
    Mar 24 2013
    Oakdale, CT
    [QUOTE=A4manic;11445822]
    No it doesn't. In what world does 10mm = 1"? Last I checked, 1 inch was 25.4mm
    -Adam
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by A4manic View Post
    Regardless of size questions, you would never, ever get 4 tires swapped and balanced for $40 in Minnesota.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
