Results 1 to 29 of 29
    Veteran Member Three Rings Papa_Dios's Avatar
    Jul 01 2010
    fl
    Project Jade "Three Wheels Out Of The Garage"
    So I got everything buttoned up and started her up. However, now the A/C and radio do not come in at all 😫😫.. A little backstory I originally took it off of the road because the accessory belt flew off damaging my oil pan sensor (I have since fixed that). When that happened I heard a fuse pop (turned out to be fuse #34 which I also replaced). Anyone have any ideas?
    Figured I'd make a thread to follow it's progress based off of my other thread : Coolant Temp Sensor Help. Pics to come.
    Finally off jackstands!!!!!!!!!!!!!!!!!!!!
    My 5 speed swap thread
    Parts I have for sale!!!
    Jul 01 2010
    fl
    Changed out my snub mount today. Also took the time to do the accessory belt tensioner. But like all things with this car another issue has popped up. The belt keeps wanting to walk off of the pulleys/tensioner. I am at my wits end between this and the radio/ac not working. Looking at the tensioner and other pulleys as its running doesn't indicate that anything is bent or crooked but I can't think of any other explanations.
    Sent from my Z987 using Tapatalk
    Jul 01 2010
    fl
    ANYONE????
    Aug 09 2012
    2013 S4 phantom pearl
    IL
    are any of the grooves damaged on the belt? grooves on pulleys okay? any other work done to the pulley/vbelt prior to the FIRST belt flying off? it sounds like whatever caused the belt to fall off track the first time is still an issue. I'd look deeper to address that before assuming it's good to throw another belt on and be done. if you used the same belt, I'd absolutely replace that. the shoulder of the one in the pic looks pretty gosh darn warn.
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    Double check that you seated the tensioner correctly. There's an alignment pin thing on the back side.
    Jul 01 2010
    fl
    Quote Originally Posted by das4 View Post
    It's a new belt the belt prior to was a conti belt (which pisses me off). The grooves on all of the other pulleys look to be in normal shape. That's what confuses me.
    Jul 01 2010
    fl
    Quote Originally Posted by y3ti View Post
    The pin was removed (after the belt was installed so that the tensioner gets rid of the slack). If you see anything out of place please LMK. Thanks guys.
    Jul 04 2012
    Woodbridge, VA
    How long does it take to walk off?
    Jul 01 2010
    fl
    Quote Originally Posted by vavJETTAw36 View Post
    I can place the belt correctly and it seems like as soon as I start it up it begins to travel off. It doesn't take long at all. I way to correct this before it walks completely off and destroys something else 😒😒.
    Jul 04 2012
    Woodbridge, VA
    Any play in any of the pulleys?
    Jul 01 2010
    fl
    Nothing to note.
    May 25 2014
    Long Beach, CA
    i meant the nub on the back side of the tensioner. i suggest making sure that nub is lined up right. your pictures make the tensioner look crooked.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Are those pics after the belt engine has been started?
    Without the belt does the tensioner arm have any movement besides normal tensioner movement? Can it be pulled away from the engine?
    Do you have a straight edge to check all of the pulley alignments?
    Does the new belt walk off the old tensioner?
    Jul 01 2010
    fl
    This spot correct? I'm pretty sure that it is in correctly. I'll double check it though.
    Jul 01 2010
    fl
    Quote Originally Posted by Zba View Post
    Yes not soon after starting the car it begins its travels. Nope just the normal movement. It's too tight to pull away. The old tensioner is gone, but yes it was walking off of that one as well which is why I replaced it thinking maybe I received a dud.
    Jul 01 2010
    fl
    As for my a/c not working I found the culprit. I don't know why when I checked earlier it looked good smh. The radio still isn't working but I figure that if I check the fuse in the back its more than likely blown.
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    one of your pulleys is mis-aligned or possibly bent if the belt is walking off. From which direction does the belt begin to walk? I would work back from there and examine each pulley in line. Maybe have a friend start the car while you inspect the pulleys for wobble. The belt should not walk off unless something is pushing/pulling it off. I doubt your tensioner is bad - both your old and new tensioner are acting the same.
    Jul 01 2010
    fl
    Turns out the a/c compressor pulley is bad causing it to run uneven. I dropped it off at my buddies shop so that he can fix that (I wasted my week off working on this thing ) put my rebuilt axles in and some other things. I'll keep this updated.
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    Quote Originally Posted by Papa_Dios View Post
    What was the culprit? The fuse? Where @??? I am in the same boat. But got my radio working
    Sent from my SGH-M919 using Tapatalk
    Jul 01 2010
    fl
    Quote Originally Posted by Royal769sr View Post
    Yes although my radio isn't working (I'm almost positive it's the fuse in the back.) You're going to look for fuse #5 (10 amp) on your fuse panel (drivers side dash)
    May 22 2013
    Las Vegas, NV
    Thanks man
    Jul 01 2010
    fl
    Thanks man
    No problem
    May 22 2013
    Las Vegas, NV
    Dang man. THANKS!!! It worked
    Jul 01 2010
    fl
    Awesome!!!
    Jul 01 2010
    fl
    So I'm at a crossroads here, I've decided to keep the car but can't decide whether to go single or F21. I know that it's two very different animals with their own pros and cons. My power goals are honestly ~430whp. Has anyone used the Project B5 STK? Thoughts?
    Dec 10 2013
    Borden, Ontario, Canada
    For 430whp? Stick with twins. Big single for highway fun
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jul 01 2010
    fl
    Quote Originally Posted by Bordom View Post
    That's what I was thinking thanks for the input.
    Sent from my Z987 using Tapatalk[/QUOTE]
    Jul 01 2010
    fl
    Anyone know the part number for the smaller belt that deletes a/c by any chance?
    Jul 01 2010
    fl
    Quick update as you can see the compressor bracket is actually cracked.
    Grabbing the part from ECS tomorrow. This stupid little stuff is really holding me back from going stage 3......
