Results 1 to 9 of 9
    Senior Member Three Rings 2modfast's Avatar
    Sep 20 2006
    ? For those running 3mm & 5mm spacers...do u need longer bolts?
    Quick question fellas...a buddy of mine claims you don't need longer wheel bolts when it's a 3mm or 5mm spacer. Anything longer, you will. Thoughts/Comments?
    A man is defined by two things in life...by his WORDS and his ACTIONS.
    **FOR SALE...B6 S4 OEM DownPipes**
    Senior Member Three Rings drdrewusaf's Avatar
    May 31 2012
    San Antonio Texas
    You should have 6.5-8 engaging turns when tightening your bolts. Stock, I had 7 turns. When I put my 3mm spacers on, I was getting 4 turns. So, I would say yes, but YMMV. Check to see if your bolts turn enough times with a spacer on. If not, get new bolts.
    Drew
    Account Terminated Four Rings
    Sep 13 2014
    New York
    Yes
    Sep 28 2010
    NW NC / DE
    I've been able to use stock bolts with 3mm, but never 5mm. A nice set (20) of zinc plated bolts only runs about $70. Not worth taking chances, and if you're doing say a 5mm rear, I'd want new front bolts too so they match. OEM is 14x1.5x27 so for 3mm, 14x1.5x30 and 14x1.5x32 for 5mm.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    For maximum strength you should have the same penetration as the diameter of the bolt, which is 1/2" or 12mm in real money.
    And yes, I did just say "penetration" for the girls giggling on the back row.
    Veteran Member Three Rings mjr034's Avatar
    Jul 07 2014
    2015 Mazda 3i GT
    Michigan
    Quote Originally Posted by JamesRS5 View Post
    +1 for penetration
    2013 S5 3.0 TFSI ~ Prestige | DSG | Brilliant Black | Carbon Atlas
    | 034 | APR | AWE | BBS | BFI | BILSTEIN | ECS | VORSTEINER |
    Established Member Three Rings miked1978's Avatar
    Oct 27 2015
    Houston, TX
    size does matter
    Feb 27 2014
    Dubai
    Quote Originally Posted by miked1978 View Post
    size does matter
    If your length matches your girth then the above is not relevant.
    Sep 28 2010
    NW NC / DE
    Here for penetration! I'm driving.
