Originally Posted by
GramCracker
Definitely made the correct decision for now, that's for sure. Tuna and catted DP down the road
I'm just talking based off of my experience running a completely catless and resonatorless downpipe on this motor without a tune. If the post-cat O2 sensor is not reading the cat as being efficient or functional, isn't it going to mess with things? I'm probably mixing up the that with the AFR (long day at the office), because then that reading the exhaust gas without a cat, IMO would definitely throw things off. The way the car started acting under full-load WOT situations after I puts some miles on the car with the catless setup definitely wasn't right.
One thing is for sure, the OEM tune with a catless DP was causing my car to DRINK petrol at an almost hilarious rate - seemed like I was driving a V12 without the amazing sound or power.
The reason for using a lot of fuel Graham is because the Simos ECU's use torque based fuel management. The ECU is compensating more fuel based of the engines volumetric efficiency. More air, more timing = more fuel. These ecu's are so smart they actually can predict what the calibration is calling for boost wise by monitoring turbine power and shaft speed to set the wastegate duty cycle before it even happens to help aid in driveability and smoothness.
Blaine
^ Theres the CEL fix for DP's. Just gotta pay the big $$. A year wo/a CEL is a LONG F'n time. Stock cars get a CAT CEL more than that! The awe DP is "No Check Engine Light - Guaranteed," and they are the only DP that claims that.
If your tuned and the CEL come on just reset the code. Not going to harm anything. Now the Untuned guys an aftermarket DP wo/running NO CATS.. well your just rolling the dice. AFR's will be all out of wack.. Lean/Rich issues. Not good on a boosted engine. At least run a log on dyno to make sure... heck of alot cheaper than a new motor.
We love AWE Tuning, and love that there are no CEL's using their downpipe. But, I am a firm believer in not using any downpipe on an un-tuned car. Whether it has a high flow cat or even no cat etc..it can be detrimental to the engine and the car will not perform right. Graham is a testament to that. These MQB engines need tuning to allow safe efficient operation. There are values that are limitations in the engine calibration that determine volumetric efficiency and AFR. Parameters such as preturbine exhaust speed, low pressure and high pressure fuel values, turbine shaft speed, intake air, and EGT all play a key role among with other limiters from the ABS, traction control, oil and coolant temp, VSS, DSG torque limiters that are other road blocks. All of these values are effected, not just AFR, boost, fueling etc like it used to be.
