Results 1 to 23 of 23
    Roc euro intake. Rubbing on silver pipe??
    I know there is already a thread for this but can find it for the life of me. As I said, the intake pipe is rubbing on the silver pipe ( I think it's an oil pipe, it gets damn hot). To the point it's showing some wear on the silver pipe. For the life of me, I can't adjust it to clear it completely. Sometimes I can get a little gap in there but I bet as soon as I shut the hood, it's rubbing. Anyway, is there any high temp tape or wrap I can wrap that portion of the silver pipe with to prevent further wear??? Thanks!!
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Quote Originally Posted by derek.kritz View Post
    Derek, here is a link for the thread. I bought a 1" diameter rubber hose from Auto zone and covered the ac line for a couple bucks. Some were able to get the hose for free. Hope this helps.
    http://www.audizine.com/forum/showthread.php?t=691322
    Sent from my mind
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Here is the thread.
    http://www.audizine.com/forum/showth...d-their-intake
    Mine was doing the same thing so I bought a small piece of rubber heater hose from Pep Boys and zip-tied it onto that pipe. It's been good ever since.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Same here, I used the hose trick and no problems.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Derek, the roc euro coupler is so soft and weak, it flexes.
    I bought a silicone coupler from autozone and I was able to adjust it away from the coolant line.
    Just throwing another option
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Oct 14 2012
    Empty...for now...
    SE PA
    Would anyone mind sharing some photos of the Roc Euro system installed, specifically showing where the intake tube passes thru the opening in the heat shield? In my opinion if it was designed properly, when the intake tube is bottomed out on the bottom contour of the heat shield cut-out, there should be adequate clearance between the intake tube and the silver AC line in question. Apparently this is not the case?
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Quote Originally Posted by SteveYem View Post
    I too had the rubbing issue a while back and came up with a solution that has been working great.
    Here's what I did... Wrapped the tube in exhaust/header wrap and at the point where the intake tube rests on the heat shield I wrapped around a couple extra times, such that the wrap ensures that the tube is elevated from that coolant pipe... I have a pic from a while ago that might help you visualize this (directly to the right of the clamp on the filter is where I wrapped around extra):
    Also link to header wrap: http://www.summitracing.com/parts/de...1/media/images
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    The intake tube *is* bottomed out on the heat shield. The problem is that the heat shield itself is so poorly anchored in the engine bay. So, the whole shield moves, which then allows the intake tube to come into contact with the AC line.
    Sep 15 2013
    MD
    Quote Originally Posted by mrmomo313 View Post
    Looks good.
    Sent from my mind
    Thanks for the suggestions guys. So that silver pipe is an A/C line?? Could of sworn i touched it once and burned my hand?? Cool. Will wrap it with the hose. Thanks!!!
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by jsh139 View Post
    LOL
    Wow that's pretty poor. Not to ignite the whole RocEuro vs CTS thing - but CTS is just doing it so much better. Based on the various improvements present on the CTS I wouldn't even call it a copy. If it was a copy it would have the same shortcomings as the Roc Euro.
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    these threads make me want to buy the $299 ECS intake. for $20 more, it seems its worth not having to deal with the headache.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    No you're right, its a coolant line. People get confused because it sort of looks like an A/C line.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Quote Originally Posted by melomandn View Post
    Right. It's defiantly coolant. Is wrapping it in a rubber tube safe?? Has anybody that has done it seen any "meltage?"
    Oct 14 2012
    Empty...for now...
    SE PA
    I do not know whether it's safe, but I would be more inclined to find a way to anchor that heat shield and/or add some sort of cushioned shimming between the intake tube and the bottom contour of the heat shield cutout to keep the tube away from the coolant line.
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    I used heater hose. It's designed to carry hot coolant. The stuff I used is rated from like -40 to +257 deg F. So it damn well better not melt . You can buy silicone hose that's rated even higher, too.
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    LOL
    Yeah, it could be better anchored to the air inlet. The CTS one hooks in while the Roc just kinda sits there. I still love mine though :)
    Established Member Two Rings ZGskibum's Avatar
    Jan 17 2016
    Aspen, CO
    I used two 12" zip ties to hold the intake hose at the top of the heat shield. Maintains about a 1/2" gap from the coolant line. I'll post pics tmw. Definitely a jury-rig solution, but zip ties are a helluva lot less expensive than a new intake.
    2011 S4 6MT Sport Diff | Ibis w/ Black Optics
    APR Stg II+ | AMS Cooling | AWE Touring - Res DPs | Roc Euro Intake | Sachs X-Tend Clutch w/ USP SS Line & Lutz (OEM) FW | Stoptech ST-60 355 BBK w/ SS Lines | H&R OE Springs | Bilstein B8 Shocks/Struts | CR-15 | H&R Rear Sway | Alu Kreuz | 034 Trans/Engine/Diff./Strut Mounts | BC Forged EH 307 19x9 ET 40 (Summer - Michelin PS4) | VMR V810 19x9.5 ET 40 (Winter - Pirelli Sottozero) | ECS Shortshifter | P3
    Mar 21 2015
    Quote Originally Posted by ZGskibum View Post
    It's not the intake to worry about.
    Jan 17 2016
    Aspen, CO
    Right. But a different intake is the "real" solution to stop the intake from rubbing a hole in the coolant line.
    Veteran Member Three Rings VR2V8's Avatar
    Dec 20 2007
    Philly Area, PA
    Every time this comes up, I go and check mine again with the expectation that I have to go buy some heater hose. I've had the intake installed for 3 years now and check it regularly anyway and it has never moved or rubbed on anything.
    2022 SQ7: P+, Daytona Gray Pearl/Black, Alu Optics, Ambient Lighting Package, Extended Leather Package
    Audi All-Season Floormats/Trunkliner, Llumar CTX 35%
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Pics plz
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    I had the intake on for about 2,000 miles before I caught wind of this problem on the forum and checked. I had a small clearance gap, but the damage was still there. I tried adjusting the intake but couldn't find a position where it wouldn't hit. Finally ended up wrapping the coolant line with a hose.
    A pic of the line and bottom of the intake:
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
