i started getting the stop car and check oil alarm on my car, it comes and goes but usually when staying idle or at a light, then after i start driving it goes away. after plugin vcds on it i got this alarm
5582 - Oil Pressure Switch for reduced Oil Pressure
P164D 00 [039] - Malfunction
Not Confirmed - Tested Since Memory Clear
i checked oil level, everything is ok, either way got the oil and filter changed, but problem remains
i also took this read in Advanced Mess Blocks
179 Status of oil pressure switches 0 this is usually in 1 but in idle it goes to 0
you guys think this is faulty?
