I have a 2001 A4 with a 2.8. It has several codes, mostly a misfire in cyl 4, 5, 6. New to Audi, I am assuming this is a bad driver side cam tensioner. Most of the time it runs fairly smooth, occasionally it will run rough, there is no excessive rattling or metal noise. So I am just ready to tear in to it. I have tried reading everything I can prior to starting. Mostly what I have read has been about the pass side. Can this be done without removing the timing belt? Removing the front bumper? Can it be done by lifting just the intake cam? The left and rear are 2 different sensors, correct? Is there a good DIY step by step a person can read for this job?
Thank you for any advise.
