Results 1 to 8 of 8
    May 31 2014
    Alabama
    Delete Previous Contacts
    Ok, so I know this is probably a common topic, but I haven't been able to find anything.
    I got my car CPO and the previous owner's phones were linked via Bluetooth. I deleted all bonded devices and contacts. However, whenever I go to Telephone -> Memory -> Memory Capacity and scroll down, the owner's phone names and used memory capacities appear.
    I've tried "Delete Directory" to no avail. Granted, I don't see his contacts, but only his phone memory capacity.
    Any suggestions to completely remove all mentions of his phones?
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
    Mar 21 2015
    Did you try the manual?
    Senior Member Two Rings UberBrute's Avatar
    Jan 05 2014
    E91 BMW 328xi 6MT
    Connecticut
    i had the same problem when I got my CPO, i ended up doing a full factory reset of the mmi and that cleared everything.
    SOLD 2013 Audi S4 | 6MT | Estoril Blue Crystal | Premium Plus | MMI Nav Plus | Sports Differential | Carbon Atlas Inlays | Alcantara inserts | 19" Peelers |
    May 31 2014
    Alabama
    Sure did, but it seems to be a glitch that when I remove all devices and delete the directory, the memory contacts still stay for whatever reason.
    May 31 2014
    Alabama
    Quote Originally Posted by UberBrute View Post
    When you did this, I assume you then had to go through all the random settings and customize again?
    Nov 27 2007
    Jersey City, NJ
    Went through this recently when i picked up a CPO 2 months ago... if i recall correctly when you go through the option of resetting the MMI to factory it takes you to a screen with what options you want to reset with checkboxes, with phone settings/contacts being one of them.
    Jan 05 2014
    E91 BMW 328xi 6MT
    Connecticut
    Quote Originally Posted by AudiS4SD View Post
    Yea I did have to redo all my settings. I didn't mind though since it gave me a chance to readjust things a little after having used the car for two weeks. That way I was able to more finely tune the settings (if that makes sense).
    May 31 2014
    Alabama
    Thanks I'll have to give it a try.
