Results 1 to 3 of 3
    Jul 10 2015
    SATX
    Tiptronic shifter warm while driving -Is this normal?
    My new to me 05' Allroad 2.7T Tiptronic shifter stalk and surrounding area (metal/aluminum bits) seems to get warm to very warm while driving (more so hwy speeds cruising 75-80MPH). Is this considered normal or is it a symptom of an underlying issue?
    Temps in TX are coolish recently (50's-80's) and the mentioned areas are not warm from direct sunlight exposure prior to driving. Shifting seems smooth and within normal limits as far as I can tell.
    Please let me know if I am overreacting or if I have reason to worry.
    -Eric
    It could be normal but, I would check to see if the heat shields are in place or missing
    Using Tapatalk
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    i would say its normal, mine gets warm in the summer when ive been driving for a while
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
