Originally Posted by
jesse500
Is there a particular resistance reading I should get from window circuit? I realize if 0, then she broke, but I know its quite an intricate web of wires, still may have some resistance, but be broken.
I am not sure, the specificaton is in the Bentley, I will check that.
If the window heater is open circuit there will be infinitely high resistance, more than the meter can measure indicated by OL. or similar.
If the heater is shorted, or the power supply wiring is shorted to ground, the resistance measured from the hvac controller end will be lower than spec, and there could be continuity to chassis ground. That is, measurable resistance to chassis ground.
There should be no continuity aka an open circuit to chassis ground.
