Results 1 to 14 of 14
    Established Member Two Rings briansubsist's Avatar
    Aug 20 2014
    2016 Audi Q5 3.0 Sline
    Grand Rapids, MI
    Stock downpipe with HFC and Aftermarket exhaust?
    Is anybody currently running an aftermarket catback exhaust with a HFC but using the stock down pipe? There isn't anything wrong with doing this is there? It seems like most of the down pipes only provide some additional noise but not anymore power. Thanks for any input.
    Senior Member Two Rings Grippy's Avatar
    Feb 01 2016
    2000 Wrangler Sahara
    Littleton, CO
    My understanding is the only performance to be gained from the turbo back (using stock turbo) is in the cat itself. Anything else may be more for looks/sound.
    Fool me once, shame on you. But teach a man to fool me, and I'll be fooled for the rest of my life.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    I think a lot of people have an HFC, stock downpipe and aftermarket exhaust
    #pedalresponce
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Jun 26 2009
    Bremerton WA
    Look at it this way. It you are connecting to the HFC using a stock size flange and the exit is the same size as well, how much can you possible gain.
    VMR 710's, APR software, Eurocode HFC
    Aug 20 2014
    Grand Rapids, MI
    Quote Originally Posted by van462 View Post
    Ha! Good point. :)
    Registered User Three Rings MagnaFlow's Avatar
    Jan 26 2015
    Oceanside, CA
    No problem with that at all! Quite a few owners run a similar setup to that to gain a little power without the smell and CEL issues.
    May 24 2007
    PA
    This is the direction I'm heading because I don't want a loud exhaust.
    Dec 01 2011
    what about an HFC with a stock exhaust as well? i had an OEM S4 quad exhaust fitted to mine, it's mainly just the back half of the S4, nothing up front has changed from the stock A4 exhaust. and i may want to Stage 1/2 later on. i'm not too worried if i dont get too much of a power increase with the HFC with stock exhaust, but will the sound be ok? i know the HFC makes it a bit deeper, but will it sound too raspy or off or anything with the stock exhaust? my original cat is starting to go bad i think, and i'm wondering if i should just use the opportunity to get an HFC or just get a normal oem cat. i know i won't get power now but later on if i go Stage 1/2 i would get something, but just want to make sure the stock exhaust isn't going to make the HFC a bad choice.
    IG @theshawon
    Established Member Two Rings inv3rtig0's Avatar
    Oct 22 2014
    1976 Toyota Celica GT
    Paso Robles, CA
    Quote Originally Posted by Liquid Smoke View Post
    HFC with stock exhaust does not sound raspy at all. It increases the tone a bit, gives it more of a low grumble, but its very subtle. Also, you will get a performance gain right out of the gate, even without a tune. Its claimed to be somewhere in the 20hp range. I ran stock tune + HFC for a few months before going stage 2 (skipped stage 1), and I definitely felt the power bump with just the HFC.
    2010 A4 Quattro Prestige 6MT S-line | build thread
    Revo stage 2 | 034 HFC | AWE Quad exhaust + downpipe | 034 trans mount insert | interior LEDs | ECS short throw shifter
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by inv3rtig0 View Post
    +1
    I did the same
    #pedalresponce
    Established Member Two Rings RW12's Avatar
    Dec 28 2015
    1997 Safari van, SV650 Superbike, YZ85 supermoto
    Vancouver
    With that setup (HFC and stock exhaust), did you get the smell that some people talk about? I've got 2 kids that occasionally ride in the car with me and I don't want any stinky gassy smells in the car.
    I'm currently stock tune as well, but was about to get Unitronic stage 1 in a few weeks time.
    Oct 22 2014
    Paso Robles, CA
    Quote Originally Posted by RW12 View Post
    No stinky gassy smells with the HFC. You only have to worry about that if you go catless (ie, test pipe).
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    I've ran an HFC, Stock DP, AWE Quads for over a year now. No issues what so ever.
    Some companies sell integrated DP's that are the Catalyst + DP, while others sell just the HFC and/or DP separately. It's all mix and match for the most part. A standalone DP is basically just for additional acoustics.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Dec 28 2015
    Vancouver
    OK, that's great to know. I think I may invest in the HFC then before the tune.
