Results 1 to 10 of 10
    Sep 28 2009
    suburb
    adjust LED headlight aiming
    I'm getting ready for my s7. I want to try VAGCOM for air suspension height, but I read the LED lights aim lower. Then I read the tech can adjust it via computer.
    Can this be done with vag com? Thanks
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Dont really need to adjust too much for lowering suspension through VAG. Once you go lower with links then you should readjust the lights. I had the links on my previous S6 and not on current one but both lowered 17mm through VAG. No issues seeing perfectly on the current car. On the previous car you could see a sharp cutoff and the throw for the lights was very short.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Sep 28 2009
    suburb
    OK if I lower with links, then how can one adj the lights? I hate short range lights.
    Audi SQ7
    Audi B8 S5 (gone)
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by flyfishing View Post
    I honestly couldnt figure it out through VAG. I read in one thread a while ago that there were allen key adjusters by the lights inside the engine bay, just cant find it now. On a side note, Im selling my old links if interested PM me.
    20 BMW R1250RS
    Sep 28 2009
    suburb
    Are they airmatics? If so, what is the price? And do they work for s7?
    Anyone know about the allen adjustments?
    Audi SQ7
    Audi B8 S5 (gone)
    Mar 20 2004
    Lawrenceville, NJ
    http://www.audizine.com/forum/showth...Links-S6-7-RS7
    20 BMW R1250RS
    Veteran Member Four Rings zee007's Avatar
    Jan 12 2010
    2012 C63; 2017 X5M
    RVA
    - Zee
    Current: MY22 RS6 | MY19 Q8 | MY74 50
    Past: MY09 TT | MY10 S5 | MY13 AllRoad | MY15 S6 | MY16 RS7 | MY17 911TT | MY17 X5M | MY17 Q7
    Mar 20 2004
    Lawrenceville, NJ
    Thank you for finding that!!
    20 BMW R1250RS
    Veteran Member Three Rings tenspeed's Avatar
    Dec 13 2011
    Honeoye NY
    I adjusted my A7 lights with a turn of a screw at the rear of the light. Mine were way to short for my rural roads.
    Here's someone's picture showing where the screwdriver goes. I went two full turns and had to back off one side. Try one to one and a half and go test.
    Feb 03 2018
    Castle Rock, CO
    Thank you for the thread. Had to adjust the LED headlights on my '16 S6 and the up/down adjustment is just a tad different. About where you show the dial, mine has a plastic allen head. Counter-clockwise adjusted mine up.
