Originally Posted by
forbiddenbeat
I'm leasing my S3, so would like to avoid an TD1 flag if at all possible. I'm less concerned about paying to play than I am with potentially causing issues when I return the car.
From what I can tell, even though Unitronic can flash back to stock, it's still possible for the dealer to eventually figure out the car was tuned. A piggyback sounds like it won't have that issue, though some are saying there may still be ways of telling a car had a piggyback unit on it.
Any opinions on this would be appreciated. I'm looking for the best path to avoiding TD1, or an informed answer that there's no way to guarantee a dealer won't find something. With either a flash or a piggyback, I obviously would never take the car to the dealer with either (flash back to stock or remove the piggyback). In fact, I don't plan on visiting the dealer ever during the lease, unless I really have to (TSB, some other issue I want sorted like an electrical fault, etc.).
To the best of my understanding, TD1 is a "flash counter". Just like a flash drive in your PC once you write data, that count goes up by 1. So even if a tune is removed there is still a chance that you could be flagged.
Beyond that I''m sure that there is evidence if you use a manual controller as well. If boost, or the air/fuel ratios are way out of their normal range I'm assuming any new(ish) car logs that sort of data. That does not mean you will get caught, but if something did happen they could potentially use data like that to make it "your fault".
The fact that it's leased throws an additional wrench into the situation. I have no idea what the repercussions might be if something happened due to a tune. Could they make you buy the car? I doubt it, but I wouldn't mess with it on a lease.
Your best bet is to talk to your dealer and see what their policies are etc.. or find a dealer that is "mod friendly". I called around when I first bought my S3 and found a VW dealer that installs and warranties APR tunes. However they only warranty VW cars. They said that they would tune the Audi (and have done a lot of them), but they would not cover it. So I decided to bag tuning for the time being.
As I'm sure a lot of others will say. There is a good chance that you could tune it an never have a problem, but if you do have a problem there is an even better chance that you will be pulling at least a couple hundred, and probably a couple thousand out of your own pocket when something goes wrong. If you
know that, and can deal...tune away!!!
