Product Page
Version 2.0.1 is now available for the DQ250 DSG/S Tronic transmission found on the MK7 Golf R / S3 and similar vehicles. The update is free for existing APR TCU Upgrade customers and offers a substantial update to the existing product.
APR’s calibration experts have recalibrated the transmission to continue increasing clutch clamping pressure when clutch slip is detected. The transmission is now capable of holding higher torque levels, and the changes result in faster acceleration thanks to quicker shifts, faster clutch engagement during take off, and stronger launch control launches. The transmission remains more consistent during back-to-back testing, with healthy, properly-lubricated transmissions no longer suffering from overheat warnings with seemingly little effort to produce them. Finally, following customer feedback, part throttle shift maps have been further optimized to prevent some TCUs from continuing to race to 6th gear, or toggling back and forth between 5th and 6th.
This update is available worldwide, and currently is designed for IS38 equipped vehicles, such as the AWD Golf R and S3. Other platform vehicles, such as the MK7 GTI and A3, will receive a similar update and announcement shortly.
Quick Feature List
Faster Acceleration
Increased clamping pressure, optimized shift points, and better launch control all result in faster acceleration.
Quicker Shifts
Increased clamping pressure and optimized shift times results in a faster shift under various scenarios.
Optimized Shift Points
Drive mode is optimized for fuel economy while sport mode is optimized for faster acceleration with APR’s various hardware and software upgrades.
Increased Clutch Clamping Pressure
Increased clutch clamping pressure beyond factory torque levels to support higher output.
Smoother Daily Driving
Optimized part throttle / daily driving shift maps to provide a smoother and more enjoyable driving experience.
User Definable 3-step Launch Control
Launch control is enabled on all models featuring a traction control button. Three user defined launch control RPMs are set at the time of install. Launch control response is also optimized for faster engagement and stronger take-off.
User Definable Manual Mode
The automatic manual mode upshift and kick-down switch downshift can be enabled or disabled at the time of install.
Quicker Paddle Response
The time between clicking the paddle and the shift executing has been optimized.
Raised Torque Limiters
Non-physical transmission torque limits are raised to allow for higher output while retaining critical protection limits.
Downshift Lockout Optimized
Manual downshifts are permissible in all gears so long as the next gear is below redline.
Temperature Management Optimized
Allows for limited torque during over-temp conditions vs total immovability.
Gear Display Activated
Shows the current gear in the factory multi functional display in both drive and sport mode.
DirectPort Programming
The TCU Upgrade installs in minutes without opening the TCU and can be uninstalled at any time.
MORE DETAILS ON OUR WEBSITE
Product Page
Please schedule an appointment with an APR dealer today.
GO APR!
