I was just about to do an oil change today until I noticed an oil leak near the oil filter housing area. I tried to trace the source of the leak, but haven't gotten to removing the timing belt covers just yet. The timing belt was changed along with valve cover gaskets (again), thermostat, seals, pulleys, water pump, serpentine belt, tensioners---last year, September, 2015.
From Day 1, after getting the timing belt service done, the car made an obnoxious sound (whine) whenever accelerated, and decelerated to complete stop; sound also seemed to correspond to anytime the AC was turned on and off, as well as changing channels on the radio --- strange. I figured the PCV valve had to be changed, and replaced it, problem solved.
Lately, the car has done more local runs than driving on the express-way. Occasionally, the windshield fogs up even when the weather outside is pleasant.
The car has had the tendency to consume oil (before and after the timing belt service was done). It's been close to 5,000 miles, and I'm reluctant to proceed with the oil change before I figure the leak out.
I'm hoping none of my recent experiences have a link to what I detected today.
Coming back to the oil change, I enclosed pictures of what I've been seeing. Also note the sludge buildup on the Oil Cap. Again, lots of short-runs, local driving, after cold-startup, perhaps that would explain the sludge on the cap. Other than, would like to know if the oil leak is something which can be resolved. I didn't see any leak around the valve cover gaskets (though I haven't pulled off the timing belt covers yet).
153,000 Miles
