DBC to DBW what's needed from the parts car? 1.8t fwd a/t
Will the current cluster work or will I need to replace the cluster?
Harness will I be able to use the current harness (just re pin some) or will the whole harness need to be swapped over? Will the dashboard need to come out?
Will the a/t dbw throttle work? I've read it's different from the manual.
Facelift center console.
Is the harness easily removable without removing the dash?
Radio code, is the concert radio code easily attainable?
A/t to m/t, Does the s4 shift leather fit the a/t center console?
