Results 1 to 20 of 20
    Jun 06 2015
    palm beach/florida/USA
    How many miles do you have on your A6? Any issues?
    Looking to purchase one- want to see how far everyone has gone!
    Active Member Two Rings cjryan33's Avatar
    May 23 2013
    2010 Chevy Tahoe Z71
    Fulshear, TX
    I have 43K miles on a 2013. I have had no major issues to speak of. The only issues I have had was a rattle coming from the speaker cover in the center of the dash close to the windshield and some MMI bluetooth issues. I will say that this is my first Audi and did not realize that the AWD will chew through tires!!! I am on my 3rd set. I did get an alignment done right after putting on the 3rd set and it was off a bit. Im hoping I will get more thanh 15-18K miles out of this set.
    While I would have loved to be driving a S6 (a little out of my price range) the 3.0T is a fun and sporty car to drive around town.
    2013 A6 3.0T Quattro, APR Stg 2, Injen Intake, AWE Touring Exhaust
    Veteran Member Four Rings rayray's Avatar
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    I'm at 67k on my 2012. No major issues either. I did have the high pressure oil switch replaced recently during my scheduled service, but it was only a $150 fix. The V6 3.0T engine is probably the best engine overall that Audi produced IMHO. I'll probably keep it well over 100k...unless Audi brings the S4/6 or RS4/6 avants over.
    2019 S5 Sportback Prestige | Daytona Gray Pearl on Black | Black Optics | S Sport Pkg
    2017 Q7 3.0T Prestige | Ink Blue Metallic on Nougat Brown | Driver Assistance Pkg | 21"RS Wheels | Towing Pkg
    Veteran Member Three Rings Calimus's Avatar
    Oct 26 2010
    88' Scirocco, 89' Cabriolet, 16' A3 E-Tron, 05' FJR1300
    NW Georgia
    127k on my 2012. Car is a dream Just the know recall work has been needed for the car. Outside of that, I do my own maint and it's just been the usual (oil, filters, tires and spark plugs). Very reliable engine and trans for that matter.
    William
    12' 3.0T A6 Prestige - The white whale
    02' 2.7t A6 - Gone but not forgotten
    Nov 02 2015
    Reading, Pa
    Quote Originally Posted by cjryan33 View Post
    What bluetooth issue did u have? I just had an issue where it cut out. I was playing music through it and it just stopped playing. It said it was playing but it wasn't
    Veteran Member Three Rings RRF985's Avatar
    Apr 12 2014
    Atlanta, GA
    A little under 38k on my 2012. I've only owned the car for five months so far, however. I haven't had any issues yet and it seems to be from reading on here the 3.0T is very reliable.
    2017 VW GTI 6MT Autobahn
    2012 A6 3.0T P+ | Oolong | Black | Black Headliner | Sport | Side Assist | Cold Weather (sold)
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    That is not normal and has nothing to do with AWD. When they give you an alignment, make sure you get the print out of what the specs are. You should not be going through tires that quick at all. Unless you drive like a total hoon, in which case, nice work.
    Edit: This is my 9th Audi. My current car has ~50,500 miles and is stg1 APR tuned. So far the only issue I've had was the hood not latching, which works now after actuating the mechanism a bunch of times. on the small latches on the outside of the hood (2 primary latches). From my homework before buying, there are very few common problems with the C7 in general. A well engineered vehicle all around and the 3.0T has proven to be a reliable work horse for Audi across several platforms.
    Do it right, or don't bother.
    Veteran Member Four Rings name.goes.here's Avatar
    Mar 17 2012
    South of Boston
    2015 w/20K. No mechanical issues; to date, I only required a software update and had to replace a defective antenna. This is my second consecutive Audi, and am very pleased with both the brand and service.
    His: 2015 Audi A6/Quattro/Glacier White/Premium Plus/Bose/Cold Weather Package/Sport Package
    Hers: 2016 Infiniti QX50/AWD/Majestic White/Premium Plus Package
    Established Member Three Rings HackDevil's Avatar
    Jan 23 2016
    chicago
    47K Miles on my 2013 Prestige.
    Here's some of the work I got done:
    Rotors and Pads replaced at 35K
    Timing Belt replaced at 45K
    Audi Connect Modem upgraded to 3g and MMI Updated to latest firmware
    Bolt on the exhaust broke, and was replaced.
    Cup holder and valet cover broke/replaced
    Driver side folding mirror squeaks.
    13 Audi A6 3.0T Prestige Oolong Grey
    Here's my: Instagram / Build Thread / YouTube
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    I have 66.5K on 2012 A6. At around 45K the thermostat failed and the center bearing rubber for the driveshaft tore. Both were replaced under warranty. I have GIAC stage 2 tune along with a bunch of other mods identified in my sig. I have tracked the car over dozen times so far. Really pleased with how well it performs and it's reliability.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Jan 23 2016
    chicago
    Quote Originally Posted by jrsAudiA6 View Post
    What would you recommend fore someone wanting to start tracking our cars? Any tips or things to be aware of to expect to replace?
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    58k miles here, only issue were water pump (replaced 2 weeks ago) and thermostat replaced a year ago.
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    May 23 2013
    Fulshear, TX
    Quote Originally Posted by repnaudi View Post
    I had a very similar situation where my music would just lock up and the MMI would not respond to any of the commands. I would have to shut the car off and re-start it to get everything working properly. I also lost the 3G connectivity for the car as well and it would only display a 2G signal. I was originally on MMI version P0566. My service advisor replaced a piece of hardware to the MMI and I am now running the lates version 814. I have not had any issues with the new version update.
    Sep 05 2014
    Houston, Texas
    Just rolled 32k miles this morning on my 2012 Prestige. I've had no significant issues so far. Had a sensor go bad on the A/C and little mmi issues which have all been resolved by the dealer.
    I'll be posting a feeler sometime shortly to sell the car as-is. If I get no interest, I'll return the car back to stock and list it.
    Oct 11 2011
    2018 A5 SB
    Hackdevil,
    At the very least you want to use track brake pads so that you avoid brake fade during your track sessions. Also I would suggest replacing the factory brake fluid with something like Motul RBF600 brake fluid. Doing those 2 things would allow you to enjoy your track event without experiencing any brake issues. The only track pad I know of for the stock brakes is made by Carbotech. I would suggest their XP12 or Xp20 for the front and XP10 or XP12 for the rear.
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    2013 S6 here. I'm getting some sort of fuel sensor fault whenever the car idles in park for more than say 5 minutes. My passenger side mirror creaks like an old door when the mirror tilts down in reverse. My LCD screen seems to take it's time deploying every now and again. I'll be asking the dealer to address all of the above in 6k miles when I hit 45k.
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Established Member Two Rings AnTarbh's Avatar
    Oct 17 2015
    2008 Q7
    MN
    Sold my 2014 TDI at 37k no issues at all. Original tires had tons of life left (blizzaks nov-apr).
    Sent from my E6653 using Tapatalk
    2016 S6 Goodwood Green Pearl
    2014 A6 3.0 TDI Prestige Phantom Black Pearl (SOLD)
    2008 Q7 3.6l Premium Lava Grey
    2006 A4 2.0T MT Brilliant Red (SOLD)
    Established Member Two Rings NvThs1's Avatar
    May 22 2012
    2008 Nissan Pathfinder LE
    Plainfield, IL
    Just did my 45k check. No issues to speak of. Anything small was warranty work. I have some TSB's to complete, but have not due to the fact I am tuned and don't want the TD1 for the next 5k miles. Great car considering all the tech that can break. My second A6, my first being a C5 body and it was solid except for replacing CV boots. I think Audi makes a solid car these days compared to the 90's and such. I also have a q5 with the same 3.0 TFSI engine and it has about 25k on the clock. Works like a champ.
    2013 A6 3.0T - Modified
    2014 Q5 3.0T - Untouched (for now)
    Veteran Member Three Rings AudiA6A5's Avatar
    Dec 06 2013
    RI
    12' with 56k.....no major issues
    C7 A6 Prestige - Phantom - Sport - LED - 35% Llumar - Eibach Pro-Kit - EC S+Ls - 034 TM - RS Grill - APR Stg II
    Cayman S - Rhodium Silver - PDK - Sport Chrono| B8 A5 Cabrio - Meteor Grey (for sale) | Pathfinder - Cayenne Red
    past audis: B5 S4 | B7 A4 S-line
    Sep 06 2013
    13 with 50k miles. Stage 2 Apr for the last 45k :) . no td1, had warranty work done 3 times. Once for a failed oil pressure sensor, other time for rattles and another time for a failed door switch which made my door not lock/window wouldn't open/close.
    All covered with no issues.
    Sent from my Nexus 6 using Tapatalk
    2013 A6. Prestige/Innovation/20" wheels/LEDs
