Results 1 to 4 of 4
    Senior Member Two Rings OliNix's Avatar
    Oct 22 2014
    London, UK
    3.0 TDI Quattro (BKN) Engine removal
    So today I started to tackle changing my timing chains, as the drivers side bank one has jumped and now it won't run.
    I have removed all the front end, rads, etc. Removed all the loom, injectors, inlet manifolds and rocker covers. All the cams and followers look ok, no damage.
    Next step is to pull out the drive shafts, disconnect the prop shaft, turbo exhaust etc. And remove the engine and box as one lump.
    Has anyone removed the lump from this before, what's the best plan of attack? Drop the front subframe out onto a skate with the engine and box still attached and then slide out? Hoist out with a crane?
    Also is there anything else worth doing while it's all in bits? I'm going to take the heads off and fully decoke the intakes and an EGR delete. Have heard possibly the box mounts and snub mount are worth doing?
    Car has just done 170k miles, had a Multitronic gearbox rebuild and new turbo not long ago.
    Any help appreciated!
    Cheers,
    Oli
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    Oli -
    This site is *mostly* U.S. people and we didn't get the 3.0 TDI A4 here in the U.S. unfortunately, though I sorely wish we had. I'm not sure what other models here in the U.S. came with your same generation 3.0TDI... maybe the Q7 or Touareg, but hopefully someone else will chime in soon. I've listed 3 links that may help you below: the Q7 forum here on Audizine, the TDI & Diesel forum on VWVortex.com, and the TDIclub.com forums. Sorry, I don't know any UK-based forums that would help you out.
    Audizine Q7 forum
    VWvortex TDI and Diesel forum
    TDIclub forums
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Active Member Two Rings Nissart's Avatar
    Jul 30 2015
    Tools :)
    Nice (FR)
    Hi !
    you can have a look at this but it's an old DIY, without pictures... but you can translate the text
    http://forums.audipassion.com/topic/...es-sur-30-tdi/
    My V6 3.0 TDI Diesel B7 A4 -here-
    Jul 30 2015
    Tools :)
    Nice (FR)
