Results 1 to 40 of 40
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Bluetooth Scan tool
    I was planning on getting one of these, but decided to post here first to see what the community has to say.
    Any input is welcome.
    Thanks.
    Waiapasi2006
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    I use one. Got this 8-9 years ago on eBay for 35$. Some will say that it will damage the ecu. But I use this tool on many many cars without issues ( jap, us,euro)
    OBD droid scan app.
    Tried many time on my b7 . still no issue.
    It work as advertised. Get ecu codes and many other info.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    An ELM 327 Wifi has been plugged into my port for 4 years. I use the "Torque" App on my Android.
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Dang. $80!!11ONEONE
    I got a scanner for $9 from Aliexpress and its been working fine for 2 years now
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Veteran Member Three Rings Acme's Avatar
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    Get a cheap OBD II tool for 10$ on eBay and Torque or Carista (though I think Carista has no support for the B7, but Torque does)...
    I diagnosed a failing crank shaft position sensor using Torque in 5 minutes last year. Still got charged 1.5 hours "fee" for a diagnosis at the dealer because I was out of town and couldn't fix it myself... Dealers are definitely pathetic...
    2013 Daytona Gray A4 Premium S-Line Quattro 6MT - NAV - bi-xenon - adaptive dampers - Alcantara - Eron's rear view cam
    SOLD! 2008 A4 2.0T Quattro 6MT Unitronic stage 2
    Aug 26 2011
    Louisville, KY
    Quote Originally Posted by MacFady View Post
    Same here. Going on 4yrs of a Bluetooth ELM327 in my car. Random check engine lights are no longer an issue, as they can be cleared, checked, etc. Same goes formonitoring things like coolant temp, boost, ignition timing, etc.
    Anyone know of a way to use Torque to track misfires before they set a CEL?
    Veteran Member Three Rings ignus99's Avatar
    Nov 08 2009
    Calgary/Alberta/Canada
    Came here to suggest this. $10 for the ELM 327, $5 for torque app, good to go for 90% of the issues with your car.
    The other 10% require a Vag com cable and the associated $$$ to buy one.
    - Karl
    Engine: GT28RS by ATP / Turbosmart 38mm dual BOV/Recirc / Carbonio CAI / APR TBE / APR Testpipe / REVO St2+ / Snow Performance ST2 / APR HPFP
    Body/Suspension: KW V2 / DPE ST-10 19x8.5 et35 / Thor Skid Plate
    Pretty Stuff: AWE Vent Boost Gauge / OEM Bixenon + V4 LED / Supertones / Votex SS / CF Hood & Mirrors / RS4 Grille & Fogs
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Thank you all for your input.
    I don't really want to be driving around with a laptop and rosstech cable. I am going to use this on multiple vehicles.
    So, it's just up to my choice what I want to spend.
    Now, do you need to leave it plugged in to the OBDII socket?
    Sent from my SM-N900P using Tapatalk
    Waiapasi2006
    Established Member Two Rings Snowboardguy989's Avatar
    Feb 02 2011
    F350 Dually, Volvo xc90 V8
    OKC
    Quote Originally Posted by waiapasi2006 View Post
    It puts a small drain on your battery. You have to decide if the hassle of unplugging is worth saving some battery. Also get a wifi version if you want to use the gauges.
    Sent from my SM-G920P using Tapatalk
    -JHM stage 2 - Borla exhaust - 034 RSB - ST coils w/ hyperco springs - JHM Stage 2 clutch - 034 motor & trans mounts - JHM extra short shifter - APR HPFP-
    - TP - evolution thord skidplate - Devils own W/M - more stuff -
    hood RACECAR™ spec-rear diff mount
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by Snowboardguy989 View Post
    I thought the Bluetooth one supplied that as well.
    Waiapasi2006
    Feb 02 2011
    OKC
    It does but wifi is much faster/accurate to real time
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    The actual Scantool brand ones I believe output a much higher refresh rate even over bluetooth...not sure on that though.
    May 11 2013
    I recently bought this paired with an Android phone using Torque:
    http://www.amazon.com/BAFX-Products-...rds=bafx+odbii
    It has done its job so far with clearing a CEL for P2181. If you end up using Torque, you can set up custom gauges to monitor things like oil temp/pressure and boost etc.
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by kerfuffle View Post
    I been had the torque app, but never decided on one. Now, I will.
    Waiapasi2006
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    I got this one- Latest Version V2.1 Super MINI ELM327 Bluetooth OBD/OBD2 ELM 327 Multi-Language 12Kinds Works ON Android Torque/PC https://www.amazon.com/dp/B00N2K6M2A..._mCl1wbT1VXQAY
    Works perfect with torque pro on my Kindle Fire HD6 running Fire OS 5. (I side loaded the google services for access to the play store)
    Established Member Two Rings pvltr_Chuck's Avatar
    May 05 2014
    Cedar Falls, Iowa
    Quote Originally Posted by heateris View Post
    Does this work just as a scan tool or can you customize certain settings as well? (i.e. seat bell chime delete, remove bulb out errors, one touch unlock)
    Daily - 08 Audi A4 6MT - Stage 2 JHM 91 octane - JHM short shifter - JHM test pipe - TT catback exhaust - ECS boost gauge - ECS snub mount
    Sold -- 06 Acura RSX-S 6MT
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Quote Originally Posted by pvltr_Chuck View Post
    The hardware should work but you will probably need the Carista software app to change seat belt chime delete, etc. Research Carista to see if it will work on your car.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Aug 05 2010
    Central IL
    This is the one I purchased but using it with a different software app. It works well.
    Jun 15 2010
    London, Ontario
    Quote Originally Posted by doughboy17 View Post
    You can't do customization on B7s with Carista. The ELM327 readers don't support the protocol used in the B7, apparently.
    Aug 16 2004
    SE PA
    No, torque pro doesn't do any of that stuff. As far as I know only VCDS and the foxwell scan tool can do the coding.
    Senior Member Three Rings dba4's Avatar
    Sep 02 2010
    Markham/Ontario
    Also i found that if you have bluetooth in the car and try to use a bluetooth ELM you will have issues, I have the wifi one and it works great. I use the dash commander app.
    Veteran Member Four Rings 2pointOh's Avatar
    Dec 08 2013
    Buffalo, NY
    Do you need a mobile hotspot to use the wifi version? How does it connect?
    2006 A4 2.0T 6sp. JHM Stage 2 93 Oct. JHM TP-DPY to S4 Exhaust. GFB DV+. AFE Dry Filter Drop-In. 034 Engine Mounts. ST Coilovers. ECS RA4 LW SMFW and RS4 Clutch.
    Aug 16 2004
    SE PA
    Quote Originally Posted by 2pointOh View Post
    The unit creates a small wifi network and you just join it.
    Dec 08 2013
    Buffalo, NY
    Oh that's cool, thanks for clearing that up
    Feb 22 2016
    SW Ontario Canada
    I'm using the elm & Torque pro as well. A few things don't work like oil temp etc but overall great for 35$ total. Super bummed that carista isn't compatible
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Does the ELM work with DashCommand on iOS? Or what are people using on iOS? This looks cool.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by mnuttall View Post
    False. The ELM327 is just a communication device. You can call it the middle man between the cars computer and your computer phone or whatever. Real reason is accessing the parameters and such is kept proprietary.
    Aug 26 2011
    Louisville, KY
    Quote Originally Posted by dba4 View Post
    I have both bluetooth pairing between the car and with the ELM327 running concurently. I've even gone so far as to take a phone call while logging without any ill effects. Works just fine.
    Jun 15 2010
    London, Ontario
    Quote Originally Posted by Sanjman View Post
    http://www.caristaapp.com/2014/06/12...-skoda-models/
    Just quoting them:
    "The 07 A4s (B7) us an older communication protocol that's not supported by standard ELM327 hardware. So we won't be able to do it with this hardware, sorry. If at some point we develop a different type of hardware adapter, it may be possible, but it won't happen in the near future."
    Nov 16 2006
    Skokie, IL
    Just quoting them:
    Damn! First I've heard is this. Thanks for the info. For now you've trumped me!
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    I use an ELM 327 with dash command on my 2006 with no issues at all.
    Oct 31 2014
    NH
    Quote Originally Posted by audihere06 View Post
    Sweet. Definitely something I'll pickup in the future.
    Nov 11 2013
    Charlotte NC
    Quote Originally Posted by adam044 View Post
    Just keep in mind that the Bluetooth ELM 327 will not work with IOS devices so you would need the wifi version if using IOS. For some reason apple keeps the Bluetooth capability on lockdown. I use it with my android tablet with no issues.
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    There's one called the Carista that works with both android (Bluetooth) AND iPhone (wifi). It's kinda pricey at $40 but it's a lot smaller and prettier than the other ones out there too. That's the one I have and it works beautifully.
    2007 Porsche Cayman | 5MT
    Senior Member Two Rings GSXeclipsePSI's Avatar
    May 09 2012
    2000 A6 2.7t
    Hudson, FL
    The ELM327 is awesome I got it for $11.
    Torque is a great app for $5
    I just got a new app 2 weeks ago. It's $13 but has full DTCs for every make and model car.
    For Audi's they allow you access to the the ECU and TCU.
    Here is the link to the PlayStore. I highly recommend it. It's simple and gives you all Audi database.
    It is without a doubt the best OBD2 app.
    OBD2 Facile
    https://play.google.com/store/apps/d...facile.android
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Jan 24 2010
    norcal
    For those with iPhones, which obd2 wifi device did you get? And are you able to read coolant/oil temps as well as boost levels?
    I'm having trouble sorting between all the different obd2 wifi vs elm327 wifi ones for sale...
    Sent from my iPad using Audizine mobile app
    Junior Member Two Rings
    Jan 02 2014
    Frisco, TX
    Quote Originally Posted by ksteezy View Post
    There are actually a couple of bluetooth ones that work with the iPhone. Apple requires that bluetooth accessories like these use only Bluetooth 4.0 Low Energy, which most OBD devices don't. However there are two good ones that use Bluetooth LE and are iPhone certified. The one I use is called the LELink, and is available on amazon here:
    http://amzn.com/B00QJRYMFC
    I used to use a generic WiFi one before i got the LELink and I found that the LELink one connects much faster and has a slightly lower latency in the measurements, not to mention the much lower power consumption. I actually used to end up unplugging the wifi dongle because it would interfere with my remote door lock/unlock and reduce the remote range to a few feet from the car. The bluetooth dongles also solve this problem, so i'd recommend spending a little more and getting the Bluetooth one.
    Also in case anyone was wondering, I found OBD Fusion to be my favorite application, but most all of the popular ones support the bluetooth low energy dongles too.
    Jan 24 2010
    norcal
    Came here to say I bought the $35 lelink obd2 Bluetooth le scanner and the $10 OBD fusion app for my iphone6. Works as described and you can even sync logs via Dropbox to view on your computer.
    Does anyone know if our car monitors oil temp? That sensor seems to be inactive or not working for me
    Aug 16 2004
    SE PA
    I don't think we can get oil temps. Torque Pro doesn't read them either.
    Aug 06 2016
    AZ
    OBDLink MX and tried all sorts of Apps on my Android phone and OBDWiz on my laptop and nothing seems to allow me to do Adaptations or the like. Carista says its not compatible with my MX. was going to look into VCDS-Lite as an option but can't find anyone that says it connects. so did I buy the wrong adapter? I want to be able to scan and perform a few mods like window function with remote and EPB for brake job. I'm looking for suggestions on what I should look into using with my MX.
    I can't believe how hard it is to find answers to this. bits and pieces all over this website but nothing specific about my setup. (07 S6 V10).
