Results 1 to 15 of 15
    Active Member One Ring andynam89's Avatar
    Aug 10 2014
    Bergen County/ NJ
    Car overheated on a 2010 CPO s4
    I drive a CPO 2010 Audi S4, MT, stock with only intake and exhaust at 68K miles currently. Car was bought August of 2014 with 44k miles and have warranty until August 2016. I drove the car around the neighborhood for like 20 minutes today, stopping by couple places and as I was pulling up to my house a warning sign popped up on my dash saying to check coolant and shut engine off. Luckily this happened in front of my house and not on the highway. Anyway, with the thermostat recall that happen to older production B8 S4's and with this car being a CPO, should this problem have been fixed previously before I even bought the car since its a CPO and a recall was sent out a while back? Also I should be covered under warranty for this correct? Lastly, I have an CTS intake... would the dealer put this back on for me even if i got flagged for a TD1? Chances of a TD1? Thankyou
    Jun 05 2015
    Manchester
    Depends on you warranty and depends what the problem is - if it is a faulty thermostat or something then yes most warranties will cover it. If you didn't check your coolant levels and it ran dry and caused damage you won't be covered.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I don't believe all 2010s were covered under the TSB. If yours was, then I would say it should have been performed but the failure is covered under CPO anyway. Surprising but lucky that your warranty is still valid since most 2010s were put into service in late 2009.
    I would not worry about TD1.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 09 2008
    If you are cpo you are probably covered. Did it overheat or did the light just pop up? Just because the check coolant light popped up does not mean the car overheated.
    Aug 10 2014
    Bergen County/ NJ
    Quote Originally Posted by JoshDub View Post
    When i looked down at the cluster, the temp gauge was up to Hot and fan was blowing at max. Coolant levels were within normal limits without any signs of leaks.
    Mar 26 2010
    US
    Most likely it is the thermostat.
    My 2011 S4 thermostat was replaced by the recall at around 5k miles.
    The thermostat failed four years later at 34k miles. Seems to be common for the thermostat to fail again in 30k-35k miles.
    My car had no warning other than the beep, red light & announcement on the dash, since it was a hot day and the AC was already on.
    2019 RS5 Sportback
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Even the later design revisions of the thermostats don't seem to last very long. I don't think Audi has really fixed this problem.....I suspect everybodies thermostat will fail every 50,000 to 70,000 miles...
    Jun 24 2011
    Definitely sounds like thermostat. I also had my 2012 replaced a couple years back with the same symptoms.
    2012 Ibis White S4 h&r sport springs : chipwerke pro : roc-euro intake : primetime paddles : 2016 oem bo wheels : hartmann HR8 18 winter : rs4 grill
    Aug 10 2014
    Bergen County/ NJ
    so i got my car towed to the dealership and the service advisor told me that they couldn't find no faults when it was scanned and that it did not overheat when they took it out for a test drive. Can't they just replace my thermostat because thats the reason why I brought it in?
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by andynam89 View Post
    Looking at your OP, you never actually said that it overheated, despite your title.
    Did your gauge show that it overheated? If not, who's to say your thermostat is faulty?
    -Hayden
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Given the track record of the T-stat, you would think they would, but no, they won't. It's going to go, just a matter of when, best case scenario is that it dies on your way out of their parking lot.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Aug 10 2014
    Bergen County/ NJ
    Quote Originally Posted by LINDW4LL View Post
    sorrry about that, i did mention it to JoshDub's reply and wrote "When i looked down at the cluster, the temp gauge was up to Hot and fan was blowing at max. Coolant levels were within normal limits without any signs of leaks."
    Veteran Member Four Rings Joker S4's Avatar
    Jun 21 2014
    B8-S4/Q5
    Mid-Atlantic
    How long did the test drive it for? I had the same thing happen, and it was the T-Stat. But it would run just fine for close to 10 miles before it overheated again and I got the warnings. I can't remember if my car had any codes though. I had to replace mine at 38k miles.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    Quote Originally Posted by S4'ed View Post
    Interesting. I didn't realize they were prone to filing again. My '11 had it replaced at around 25K and now I'm at 62K, thanks for the heads up.
    Mar 26 2010
    US
    Quote Originally Posted by LeadToRome View Post
    Time to consider changing the thermostat again.
    Mine failed at about 30k miles after the thermostat recall, when the dealer put in a new thermostat.
    2019 RS5 Sportback
