Results 1 to 6 of 6
    Established Member Two Rings j-dells's Avatar
    Feb 09 2016
    Minnesota south suburbs
    How can I unlock my car without the key fob?
    Recently I bought a 2002 S4 and it only came with one key and no fob. I wasnt able to lock the drivers door until i used the key to lock the trunk. Then all the doors locked. But when I went to unlock the car the key wouldnt unlock the door. So I went through the trunk to unlock the car but the alarm went off and I couldnt start the car. I had to disconnect the battery to get it to stop. Is there anyway I can lock and unlock the car without this happening?
    May 16 2008
    WA
    pull the door panel off and check for missing/broken linkage originating from the lock/latch mechanism.
    Does the key turn, but just not unlock the door or not even turn (as if you inserted the wrong key)
    **Edit**
    Here is a doorpanel DIY: http://www.audizine.com/forum/showth...-Regulator-Fix
    Also there used to be a "mod" to disable the manual linkage as a means of theft protection. I cant seem to find it right now, but that might help you to know what to inspect and look for.
    **double edit**
    This is all I came across, but most of the links aren't working: http://www.audiworld.com/forums/a4-b...y-mods-179022/
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Sounds like a problem in the driver's door. Start digging. I don't even bother with the remote anymore, as my car always forgets it 3 days after programming.
    Feb 09 2016
    The key turns but it will turn all the way around. I can go forever in one direction.
    May 16 2008
    WA
    Quote Originally Posted by j-dells View Post
    Sounds like the lock itself is broken (this is a TT lock but i would guuess the S4 uses a similar design), either that or the slot on the door lock module is stripped out, but my money would be on the lock cylinder either one would keep it from unlocking manually or electronically:
    If thats the case this might be of some help: http://www.ebay.com/itm/Audi-A4-Door...-/121583447738
    Feb 09 2016
    I'll try that. Thanks!
    2002 B5 S4 SRM ko4 hybrids Stage 2 eBay tune at 21 psi
    2000 Grand Prix GTP Def not stock (Rod bearings... awkward)
