Results 1 to 1 of 1
    Veteran Member Three Rings Zerstorer's Avatar
    Feb 06 2011
    Battleground WA
    Fs:B5 S4 A6 A4 Audi Allroad OEM Metal V6 Thermostat Housing 078121121J 2.8 2.7T Audi And Passat Fits: 98 99 00 01 02 03 04 - No Longer Available
    I'm selling an Aluminum T-stat housing that would replace the cheap plastic one VW puts on Passats that leak and can put you out for a timing belt job.This one is for $75.00 + 9.95 shipping!!! this one will last a lot longer than plastic counter parts. The problem is when these warp and crack. Some of the plastic housings leak right after replacing the thermostat due to warping. It save a hefty labor bill in the long run which can be in the upwards amount of $250 and higher to replace.The solution is to replace with the more reliable pre-2001 aluminum factory part shown here during the timing service. Compare this to new at $130+ for aftermarket. This is an OEM part. 078-121-121J 078 121 121 J 078121121J
    98-04 Audi B5 S4 C5 A6 A4 Allroad OEM Metal V6 Thermostat Housing
    Please let me know if you have any??s I will answer promptly thanks for looking
    List Date: 2/28/2016
    For more info, click here to view the original listing: Fs:B5 S4 A6 A4 Audi Allroad OEM Metal V6 Thermostat Housing 078121121J 2.8 2.7T Audi And Passat Fits: 98 99 00 01 02 03 04
    This item is no longer available.
