I have A 09 Jetta with a 2.0Tsi that I just bought it has 129,000 miles on it. And it has the 000022/p0016 code and about half the power it should have. I figured the chain tentioner was going out and possibly jumped a tooth although there was no noise on startup.
So this morning I replaced the tentioner, the old did not seem any weaker than the new one. After getting everything back together I still have the code.
I know it's supposed to be a mechanical timing issue but with the code on it cranks for about 5 seconds before starting and the intake cam is stuck at 5.9 (g40). When I clear the code the cam goes to 0.0 and it fires right up but immediately goes to 5.9 and stays there regardless of rpm. Has anyone found a fix for this? I've found threads where people had the same issue but never posted the solution.
Here's a picture of the rpms G28 and intake cam timing.
Edit
I pulled the top cover and found this (see pic)
It looks like each cam skipped a tooth in opposite directions according to the dark links. How would that have happened?
