Finally got around to changing out my cam follower today and just wanted to point out some issues that I ran into.
On my 2005.5 model, I had to take off the banjo bolt first so that I could have a tiny bit more play to get at the other fitting on the fuel line.
I STRONGLY suggest you hold the banjo bolt with a strong magnetic pick up tool to prevent it from falling into the abyss!
Also, make sure you're removing the right fuel fitting. I started to move the adapter itself before realizing it was the wrong part. I was tired!
If your cam lobe is at the "top" pushing on the fuel pump plunger once you wiggle the fuel pump loose it'll more or less pop out.
When you reassemble you'll need to carefully compress the fuel pump and tighten up the torx bolt a little at a time.
The fuel pump o-ring was hard and flattened so always good to change that out. The new Audi one was bluish green in color.
Here's a pic of the old follower. 58k
