Results 1 to 16 of 16
    Senior Member Three Rings johnruan's Avatar
    Oct 01 2014
    Audi Q5
    chicago,il
    Is it something wrong with my cam
    I replace a new intake cam
    Here is the follower at 2500 miles
    So I replace a new and here is this one I just took out today close to 4k on it.
    Cam lobe
    The cam seems like fine. What exactly wrong here is it lack of lubrication? Am I missing something? Oil use is 5w40
    Oct 24 2015
    Perth, WA
    Its hard to tell, that does seem like a quick wear time, and are you sure that cam is fine? Looks a bit scored, but again, hard to tell on pics.
    My respray thread
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Wear time also depends on driving style. As long as the cam lobe still looks polished and no rough lines in it then you're O.K.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Mar 24 2013
    Oakdale, CT
    Cam looks fine to me. Do you have an upgraded HPFP? I do and I replace my follower every ~10k miles because it wears about as fast as yours seems to.
    -Adam
    Oct 01 2014
    Audi Q5
    chicago,il
    No I'm on stock pump. That's kinda fast wear for stock pump. I have to keep an eye on it after few thousand miles. I really don't drive hard on this car either.
    Feb 15 2016
    Cambridge,Ontario
    what oil do you run just out of curiosity ?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Oct 01 2014
    Audi Q5
    chicago,il
    Good question I got that thinking too. I went to this shop got good rep around here for audi. It's 5w40 but don't know what brand it is come to thinking of it I remember saw those oil they put in the shop but never heard of that brand. I forgot the name but no one here mentioned the brand b4 I'm guessing some cheap brand. I usually use mobile 0w40 but I was close to that shop so used them. It might be the oil is not good for metal to metal friction. So guess it's the oil problem?
    Sent from my SM-G900T using Tapatalk
    Oct 01 2014
    Audi Q5
    chicago,il
    I saw my invoice think the oil brand is Fuchs lubricant oil.
    Jan 24 2013
    Chicago
    If it's fuchs and you had 5w40 then supersyn is their 5w40 oil. The stuff is the same branding as Exxon supersyn. Apparently it's a PAO oil; not sure if it's a group 4 or group 3 but I wouldn't doubt it to be just a group 3 with PAO blended in. Nevertheless, it's a good oil.
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Whats your pump piston look like? Could be a chance you may have some irregular wear on it also
    2008 A4 S-line 2.0T
    JHM Stage 2
    Oct 01 2014
    Audi Q5
    chicago,il
    The piston tip look fine here is few pic of the tip.
    Feb 15 2016
    Cambridge,Ontario
    hmm this is a good one .. oil looks to be of decent quality , no obvious blemish on the cam . it is a stock HPFP right ? not an upgraded one ?
    definitely looks like a lot of wear on that tappet though . Id be tempted to take that timing cover off and have a closer look in there.
    1976 Yamaha XS 360
    Oct 01 2014
    Audi Q5
    chicago,il
    I'll just have to inspect it in few thousand miles and see how it look. I would be worried to open the timing cover don't want to see something wrong with it bc those are new camshaft and new pump. It was installed in there 6k miles only
    Feb 15 2016
    Cambridge,Ontario
    was it an Audi tappet or aftermarket ?
    the other thing that i fond out was all the marking and scratches around the none raised area of the tappet in the first pic , makes you think something is flying around in there.
    1976 Yamaha XS 360
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    Check all three lobes of the pump cam just to be sure.
    Oct 01 2014
    Audi Q5
    chicago,il
    We'll see in a month or 2 for inspection.
