Results 1 to 4 of 4
    Oct 24 2015
    Perth, WA
    Confirm DTC response please
    Hi guys
    Car has been running rough, smells badly of fuel, lurches as it goes up in speed. I had the EPC light on for a while, cleared all the fault codes with VAGCOM, drove around for a while, came back and scanned again. Now the only code is as follows (with no CEL lights).
    Address 01: Engine Labels: 06F-907-115-AXX.clb
    Part No SW: 8E0 910 115 A HW: 8E0 907 115 C
    Component: 2.0l R4/4V TFSI 0090
    Revision: --H02--- Serial number:
    Coding: 0104000002070120
    Shop #: WSC 00191 264 15243
    VCID: 1F4D8B97CE00A5C667-804A
    1 Fault Found:
    009766 - Linear Oxygen (Lambda) Sensor B1 S1 Pump Current Trim Circuit
    P2626 - 004 - Open
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 106721 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1943 /min
    Load: 9.8 %
    Speed: 33.0 km/h
    Temperature: 53.0°C
    Temperature: 27.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 14.097 V
    Readiness: 0110 0101
    I have recently installed the 034 HFC, but I think that may be a coincidence. The BSR tune doesn't disable (or manage) the O2 sensor and I haven't installed the mini-cat (034) for the rear sensor.
    Is this simply a new pre-cat 02 sensor required in your educated opinions, or should I test something out first before dropping $350+ on a new sensor?
    Thanks guys
    My respray thread
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Swap your cat back, clear codes and see whether anything changes. If it all goes away then you can rule out the sensor as faulty.
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Oct 24 2015
    Perth, WA
    Thanks for your response, I have bought a new O2 sensor pre cat and will see how it goes. Ill update the thread.
    My respray thread
    Oct 24 2015
    Perth, WA
    New O2 sensor fixed the issue. Thanks
    My respray thread
