Results 1 to 29 of 29
    Sep 28 2009
    suburb
    Non res Milltek drone question
    Yay I just put a deposit to buy an S7 and thinking of mods already! When I had my s5, I had a miltek non-resonated exhaust. I loved it and it was loud, but not too loud. I had a manual and at low RPMs it would drone (to my ears) so I found this metallic bubble wrap looking attic insulation that someone on the forums mentioned and insulated my trunk and it sounded great.
    Well the s7 has an automatic which I believe drones more AND it has a larger trunk to increase the sound. Long shot, but anyone here had an s5 with milltek and now an s7? Is the drone loud?
    Anyone insulate the s7 trunk and it decreased drone?
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Registered User Two Rings
    Aug 31 2012
    Rochester, NY
    We've got lots of experience with the different Milltek setups. I'd be happy to chat with you about the different options. Give me a call on Monday or PM me your contact info and I'll reach out.
    Veteran Member Three Rings jstrebel's Avatar
    Oct 02 2006
    Tucson, AZ
    I have a milltek non-res valvesonic on my stage 1 S7. ZERO drone.. My only complaint is I want to hear it more in the cockpit (noise cancelling and sound deadening mute it). I've actually had my wife drive it with me in the other car trailing just so I could gauge it how the rest of the world hears it. Sounds amazeballs. From the drivers seat though I still want more sound, but everyone outside is getting a symphony of Audi.
    tl;dr; zero drone, sounds amazing
    2005 A4 1.8t Ultrasport: SOLD.
    2016 S7: Build Thread - SOLD
    2023 R8 AWD Performance: Build Thread
    2024 RS6: Reel
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    Milltek resonated valvesonic with high flow cats/DPs does drone in 4cyl mode only, esp. between 60-70 mph and from 36-42 mph, and has fairly heavy vibrations around 36-42 mph again only in 4cyl mode.
    I haven't tried insulating the trunk or anything like that to address the noise. Interested to hear if anyone had success with that.
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    Quote Originally Posted by hubris View Post
    I've got the same setup and I concur with this statement. Sounds insane except for the drone in the areas mentioned ^. I was thinking my next move would be to buy a set of front resonators and have them welded in since I have the non res downpipes. Although lining the trunk sounds like a viable option.
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Nov 19 2005
    Central IL
    Wouldn't dynamat work even better?
    Sep 28 2009
    suburb
    Dynamat would be better but it's heavy. This attic insulation thing is really light and works really well.
    Thank bjs for the feedback everyone.
    I'll call you out milltek Monday
    Sep 28 2009
    suburb
    Hahha autocorrect says bjs. I meant to say thanks for all
    Jul 07 2015
    Midwest
    I just wonder how working on the trunk alone would impact the undesirable sound/feeling since I am guessing that some of it is related to the presence of the modified DPs or 'high flow' cats themselves (or no cats in madyspop's case). Insulating the car further back at the trunk might be too distal from the actual point that the sound originates from? Not sure if that makes sense. I don't' think the sound is solely entering the car from the trunk but maybe also from directly under the driver at the downpipe, midpipe, etc.
    Sep 28 2009
    suburb
    Distal? Are you a dentist?
    Well in my s5, I would hear it louder in the back seat versus the front. I believed that the trunk would resonate and increase the noise so I insulated the wheel well and it sounded less drone.
    I wonder if the s7 trunk would resonate the noise more since it is bigger and since it is a hatch, the hatch cover may be thinner than the rear deck cover in the s5 and let more noise through
    Nov 19 2005
    Central IL
    Quote Originally Posted by flyfishing View Post
    Did you just pull the trunk panels and cut and place the material or did you use adhesive to secure it in place? How much of the trunk area did you actually do, any pics by chance?
    Sep 28 2009
    suburb
    I pulled the floor above the spare tire up and used gorilla tape to tape the insulation all around there. It took me probably 15 mins to do.
    It looks like this and prob cost 10 bucks at home depot.
    Audi SQ7
    Audi B8 S5 (gone)
    Nov 19 2005
    Central IL
    I did the entire trunk floor and spare wheel well. I want to do the sides and rear wheel wells but the panels look impossible to get off. I'll report back once I actually go for a drive. If this doesn't work I'm for sure getting the front resonators and having them put in.
    Jul 07 2015
    Midwest
    Quote Originally Posted by madyspop View Post
    Wow that was quick! Looking forward to your report.
    Nov 19 2005
    Central IL
    I play no games...
    Sep 28 2009
    suburb
    What did you find out once you did it? Drone decrease?
    Audi SQ7
    Audi B8 S5 (gone)
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Interested in your results as well. I definitely get drone, particularly in D mode - and some vibrations as well. I've been meaning to have another shop look and see if it's touching the belly pan or the body somewhere. The sound in S-mode is perfection.
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Nov 19 2005
    Central IL
    Quote Originally Posted by Brooklyn View Post
    I did notice a bit of a decrease in sound believe it or not. Still haven't been on the highway but I'l do that tomorrow. I think the best thing to do in order to get this method to be effective would be to pull the rear side panels and do the entire trunk. I plan on doing that once I take a class on how to remove the side panels, it looks to be a bit of a challenge.
    I'll keep updating as I progress through this but ultimately I think just putting resonators in the downpipes will be the only remedy.
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    I just went through removing the left side panel for my ALP install, but don't have that posted on my site yet. It's tedious, but not hard. Feel free to PM me and I can likely walk you through it via a quick call.
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Nov 19 2005
    Central IL
    Well I got out not he highway today and I must say I believe the wrapping of the trunk did indeed help a bit with the drone. I think once I pull the side panels and do the entire trunk it'll be even better. I think ultimately using Dynamat or a true deadening material what give the best results. I'm going to source some and do it that way for even better results.
    Sep 28 2009
    suburb
    Glad it helped!
    Milltek guy said s5 droned louder than s7 so I bet insulated a7 sounds great.
    I didn't go with dynamat bc it's really heavy. It must weigh literally 30x or more this if I remember how heavy a box of it was. Maybe 2 or three layers of this
    Jul 07 2015
    Midwest
    Great to know! I am excited to hear your results following the more ambitious deadening What will you do with all that extra weight though! Better go on a diet to compensate.
    Sep 28 2009
    suburb
    Well I report on this soon too.
    My s7 comes Monday and I have a milltek non-res exhaust coming. I will have it installed soon and I will insulate as needed and report back also.
    Audi SQ7
    Audi B8 S5 (gone)
    Nov 19 2005
    Central IL
    She's already lost a few pounds with the new 21" Lightweight Forgelines going on today. I highly doubt the Dynamat is going to add any weight that wold be noticeable anyway, and even if it did if it kills the drone I'm good to go.
    Sep 28 2009
    suburb
    OK got the Milltek non res installed on my car today.
    Obviously this is subjective, but whoa, you guys got some sensitive ears if this is drone to you :) I had a Milltek non res exhaust on my s5 and inside the car, it was probably 3-4x as loud as this. That's why I had to insulate this. This almost sounds still TOO quiet inside the car. Once I am out of warranty, down pipes, stage 2 tune once available and more noise!
    I like the noise it makes when down shifting. This car now sounds like it should sound like!
    Audi SQ7
    Audi B8 S5 (gone)
    Jul 07 2015
    Midwest
    I think it is worse with downpipes. The stock cats must muffle some of the sound.
    Established Member Two Rings turbello18's Avatar
    Nov 12 2010
    08 Q7 Sline
    Manchester
    Fly, you go with valvesonic?
    '13 S6
    Feb 17 2004
    2013 Audi S6
    And there must be some variation on top of that...i have zero drone with dp's. Perhaps the MMI bypass is at play with mine, though.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Sep 28 2009
    suburb
    No I have the non res w/o valvesonics. The plugs for the exhaust flaps for MMI were just covered up and wrapped and taped somewhere along the bumper.
    Audi SQ7
    Audi B8 S5 (gone)
