I am parting out my Eliminator setup. These can be used on any standard KKK style turbo. I am stepping up to a PAGPARTS EFR 6758 so all this stuff has to go. These have low miles less than 10K miles.
$90 - APR R1 diverter valve less than 10K on this. New price is 169 from APR. In my opinion these are the best diverters on the market.
https://www.goapr.com/products/r1.html
[IMG][/IMG]
$240 Franken Turbo Manifold. This is an amazing manifold. Doug at Franken Turbo will not sell these separate any longer. When he did they cost 350 because they are ceramic coated. This manifold comes pre drilled for an EGT gauge and comes with the EGT gauge. I have to get a picture of that. But it cost me an addition $80. It is digital and fits perfectly into the cup holder spot above the radio. There is a VERY small crack that has been there since forever and has not moved or gotten bigger. Its less that half an inch and has not moved or gotten ' bigger. It's in the exact same spot where the stock manifold heat cracks too. Comes with grade 10 bolts and the 034 bolt holder.
[IMG][/IMG]
$220 034 High Flow Cat. Includes a 3rd o2 bung for your wide band monitor gauge. You can always plug the hole and use it when you are ready to. Light surface corrosion. HFC rule, test pipes make your car smell like azz. Get an HFC and smile while driving.
B5 S4 seats in good condition. These seats are in pretty good condition. A little wear on the driver side bolster. Check it out in the pictures. I have these currently in my B5 A4. They are not hard to swap over. I can tell you how. Or just replace your badly work B5 S4 seats with these.
Price PICKED UP in Middle River MD 200 OBO
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Thank you all
