Results 1 to 6 of 6
    Established Member Two Rings SilverB6Quattro's Avatar
    Feb 13 2015
    Earth
    Anything Im missing before Stage 1+ tune?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Just curious.....Why aren't you going with the TT225 386 injectors? (part #06A906031J)
    And you should really consider some form of intercooler upgrade. The OEM just doesn't cut it when you go to a big injector set up.
    Jun 29 2014
    America
    Metal TIP will not allow for any movement, which can be a problem if you're using a stock air box.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by SilverB6Quattro View Post
    They are the same injectors... Just a different part number. As for the intercooler I was thinking of the Apikol SMIC upgrade..
    They are not the same. They are an older version (EV6 versus EV12) I believe they have a 12° dual cone spray pattern instead of a 15° spray pattern. Here's some discussion in this thread: Clicky click®
    The metal TIP wont collapse from the vacuum when boosting, nothing wrong with the stock air box, it moves plenty of air and I was going to put on the 3.0 intake duct that connects to the radiator support, thats the only real restriction I see with the stock box.
    Don't bother with the 3.0 Snorkel. Clicky click®
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    I had issues with my long term fuel trim and running lean when I was running the Bosch 380cc injectors, switched to the TT 386cc's and all was well.
    I don't know if the spray pattern will have as much affect as the missing 6cc's (x4) but the program was written for a specific injector, use it.
    Please Drive Right
    Jun 29 2014
    America
    I agree, stock air box is fine with K03 & K04 setups. And so is the stock TIP in my opinion. With BT applications is another story. The problem is that the airbox is fixed to chassis, it does not move. Turbo is attached to the engine, wich moves up & down quite a bit. That's the reason stock TIP is designed the way it is. Unless you have flexible bands between the airbox to TIP, and TIP to turbo, something will give in with all those rigid connections. Forge silicone TIP, or similar, would be a much better choice, sturdier than stock.
