Been dealing with misfire faults for awhile now. After carbon cleaning, spark plugs, ignition coils and a fuel injector. Ended up breaking one of the arms for the runners, went with JHM and got the flaps tuned out. Removed the vacuum actuators and zip tied the flaps open. Now I've been getting a fuel rail pressure to low fault sporadically. And I've noticed in higher rpm high load like trying to pass on the highway without downshifting the car will hesitate real bad. No fuel leaks, that was my first thought, Didn't know when the fuel filter was replaced so did that last night. No change. About to do fuel pressure tests but wanted to see if anyone has seen sensors fail or the pumps. Hoping it's just the in tank pump.
Sent from my SM-G900P using Tapatalk
