After I installed a new PCV diaphragm and fixed MAF sensor wiring the car won't start. The electronics work like the dash lights up and MMI works but the car doesn't start.
Also my scanner won't read codes or even scan.
I was fixing the wiring for the MAF sensor. I used one of those wiring testers that you touch a wire and it lights up if there is a current. Not sure why that would be an issue. Doesn't seem that the PCV install would cause an electrical problem so it has to be the wiring I worked on.
Anyone know what the issue is?
