doing somewhat of a wire tuck/organizing/hiding, and i've come across a few that are not hooked up, and need some help, found most but now im tired of searching and having 30 tabs open :p
keep in mind i have a ATW engine code,
first up is this gray/white connector (wires look to be brown and white with red stripe) that sits on the same bracket as the ac connectors and electric fan connector:
that sits and connects to the one here
2nd (part of the harness on the driver side fender, pic not much help/info but the wire colors are brown with white and green stripe
these two for the b5 gods, i realized my pics aren't much help i will try and get out tmr and get better pics but here you are,
all pulled from the same harness
i think this one is a 3 connector 2 brown and one brown with red stripe
the same 3 pin connector again so you can see wires, at top left of pic
EDIT!
EDIT!
EDIT: went back through my 100 tabs again to make sure i didn't miss anything, and i think i found that 3 pin connector above, walky talky called it the cooling fan switch connector, hoping he can chime in and double check that: http://www.audizine.com/forum/showth...!-!-98-A4-1-8T
