Ok so I have a 1999 Audi A4 1.8t 5 speed that began a misfire running rough cel came on and started flashing limped it home and put the code reader to it and it says unable to establish connection I know it used to read codes cause I've had previous codes. So I've been reading forums and articles on the k line I tested pin 4 and 7 on the diag connector and have 10 volts Ross tech says need less then 9 I disconnected the after market radio and still 10 volts I've disconnected the climate control the abs module the ecu the central locking and instrument cluster and still have 10 volts is there anything else I can unplug and test I'm at a loss here
