Results 1 to 14 of 14
    Feb 26 2016
    new hampshire
    Cam follower, just replaced it @ 153k
    I swapped out my cam follower, car has 153k on it and this appears to the first time anyone's serviced it. I don't think it looks all that bad. Swapped it with a new one just to be safe. I can't post pictures for some reason, maybe because I'm new here? I can send the pics to one of you guys if you could add them in. I'd love to get your opinions. Thanks
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    At that milage and considering you already put a new one in, toss the old one in the garbage where it belongs.
    If that doesn't validate your question, maybe find a picture posted already that looks like yours that you can relate too. But in all honesty, no one will tell you to hold onto it if thats what you're asking.
    2008 A4 S-line 2.0T
    JHM Stage 2
    Veteran Member Three Rings seandon_792's Avatar
    Aug 12 2015
    Waldorf, MD, US
    Quote Originally Posted by Schweini View Post
    Completely agree here. I've yet to change mine (86k) but it's so inexpensive and failure prone that it's best to just start new everytime. Looking to do mine in the near future.
    B7 S-line 2.0
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    mine was first serviced at 100k and the follower still looked new. replaced it again at 188k and it looked the same as before. but always good to check
    Feb 26 2016
    new hampshire
    Good to hear, I was just looking to see if mine was an anomaly, it look pretty decent, warn but decent. I've seen some pics on here where there were holes smashed through. For the 20 minutes it took to swap, totally worth doing. Thanks guys.
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Np
    Make sure you keep a good habit checking that thing
    2008 A4 S-line 2.0T
    JHM Stage 2
    Oct 24 2015
    Perth, WA
    We got a photo of that OP?
    My respray thread
    Senior Member Two Rings Dad A3's Avatar
    Dec 24 2011
    2018 Audi S4, 2012 Audi A3, 2006 Audi A3, 2017 Touareg, 86 VFR 750
    Bergen Co. NJ USA
    Quote Originally Posted by millar1982 View Post
    Try putting the pictures in your photo gallery, then you should be able to post to 9the thread.
    I replaced my cam follower at 90K and it still looked good, but after all the horror stories I should have done it sooner.
    Feb 26 2016
    new hampshire
    Good to know, I'll try to add pics of it in my profile. Is this forum better suited to use at computer? Seems finicky on my iPhone.
    Feb 24 2004
    Minneapolis
    Bought my B7 with 82,K miles on it, so don't know if this is the original. But I removed this at 83,000 miles. Yours look like this?
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Oct 24 2015
    Perth, WA
    Even wear is a good sign, time to replace either way me thinks ;)
    My respray thread
    Senior Member Two Rings Detroitfire23's Avatar
    Mar 08 2012
    '92 Ford Mustang twin turbo
    Clinton Twp MI
    Mine was replaced by the dealer by the previous owner. How many miles before they go bad?
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    From a previous post:
    I'm not surprised by the highly variable nature of wear on the follower. My guess is that it depends on a number of factors, and I'll just list a few of the top of my head. 1.) As Schweini stated above the those with the upgraded HPFP are putting at least 30% more force between the cam and follower. That could result in a much greater than 30% wear difference due to the vagaries of hydrodynamic (fluid film) lubrication. 2.) Oil change interval and type of oil could be a factor, although I suspect a small one. 3.) The way the car is driven is likely a big variable. Keep in mind that the pump is activated 1.5 times per revolution of the crank. If you normally drive higher in the RPM range you are putting a lot more cycles on the cam follower that someone that drives like an old lady or someone who short shifts. 4.) Other things that come to mind are trip length, cooling system health, climate you drive in, tracking the car, etc. I'm sure you can think of other factors.
    With that my opinion is check/replace as follows:
    Stock engine, easy on car - 30K miles
    Stock engine, aggressive driver - 25k miles
    High performance HPFP, easy on car - 20k miles
    High performance HPFP, aggressive driver - 15k miles
    It it looks anything like the above picture in post #10 replace immediately
    Brillo
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Brillo View Post
    I did. I checked the new one 15K miles later, no black worn off.
