For the past few years I've had the ride height set at level 1. After approx. 6K miles, (I don't drive it often) my front tires showed excessive wear only on the insides of the tires, the middle and outside showed little wear. I replaced the tires and then it went on the alignment rack. The alignment was spot on. Next all the suspension components were checked and no issues were found. This appeared to only leave one possibility, the level 1 setting. Is it possible leaving the suspension in the lowest setting could cause premature tire wear? I've contacted several dealers and independent shops only to get conflicting opinions. Look forward to your comments.
