VCDS Scan shows 1 Fault Code:
008504 - Accelerator Position Sensors (G79) / (G185)
P2138 - 008 - Implausible Correlation
So far I have replaced the accelerator pedal and both O2 sensors but the fault code comes back immediately when cleared. All visible wiring & connectors look fine but I haven't traced them all back to their sources yet.
VCDS Block 62 shows that Pedal Position Sensor 1 (G79) reaches 76.6% max and Pedal Position Sensor 2 (G185) reaches 45.7% max.
VCDS Block 62 Accelerator Pedal No Throttle
VCDS Block 62 Accelerator Pedal Full Throttle
VCDS Block 64 Voltage Measurements are all within specification
Lower Adaptation Sensor 1 (G187)
Voltage = 0.520 V
Specification: 0.4 - 0.6 V
Lower Adaptation Sensor 2 (G188)
Voltage = 4.580 V
Specification: 4.0 - 5.0 V
Emergency Air Gap Sensor 1 (G187)
Voltage = 0.840 V
Specification: 0.5 - 1.0 V
Emergency Air Gap Sensor 2 (G188)
Voltage = 4.280 V
I'm not sure what else could be causing the issue. Any ideas?
