Results 1 to 19 of 19
Thread: No boost......
    Senior Member Two Rings lostInTheSmoke's Avatar
    Aug 06 2015
    Minnesota
    No boost......
    So recently I changed my diverter valve because I threw a code p0299 and the diverter valve is bad. So I change that and I had great boost pressure probably around 20psi. But now as of a few days later I'm having little to no boost pressure. If I get to around 4000 rpms it will jump up to about 12 psi all of a sudden, but if I'm driving normal I'll barely hit 3 psi. I did leak test and had zero leaks. Where do I go from here? Please help.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Maybe your boost gauge isn't functioning properly. Do you feel the boost come on and off like the boost gauge is showing? Or is what you feel different from what you see.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Aug 06 2015
    Minnesota
    I can feel the boost come on when the gauge shows, it's low but then when I get high on the rpms it's like a surge and then I hit like 12psi and can hold it there if I keep on the throttle.
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Ive had someone local to me have similar issues, and upon inspecting his install, he totally screwed up the DV positioning, leaving a big gap.
    Did you double check that at all?
    2008 A4 S-line 2.0T
    JHM Stage 2
    Aug 06 2015
    Minnesota
    Quote Originally Posted by Schweini View Post
    Yeah when I put it in I made sure it was fully in and tight. When I did a pressure test it would leak from the DV if it wasn't in all the way right?
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Yea I would assume so, depending on the positioning of the Dv, if it was stuck open or not. But you said there's no gaps so id check elsewhere.
    Have you checked your PCV and Cam follower lately?
    2008 A4 S-line 2.0T
    JHM Stage 2
    Aug 06 2015
    Minnesota
    Did the PCV like a month ago, but I really need to look at the cam follower now that you mention it, but haven't heard anything from there but fingers crossed.
    Aug 06 2015
    Minnesota
    So just too a look at the cam follower it was still looking good but replaced it anyways that I had the pump off. Still same boost problem,
    [IMG]https://uploads.tapatalk-cdn.com/20160228/00e465be9b12b16f29cdf4e38f30bb24.jpg[/IMG
    Aug 06 2015
    Minnesota
    Active Member One Ring zagimon's Avatar
    Feb 15 2016
    A4 2008 Audi A4 quatro S-line : Mercedes 2012 C250
    dallas,tx
    What year is your B7 and how many miles are on it?
    Aug 06 2015
    Minnesota
    Quote Originally Posted by zagimon View Post
    2005 with 170,000
    Aug 06 2015
    Minnesota
    I think I'm going to pull the DV back out and look at that, it's the new piston style and heard some bad things about them. If not look at the N75 valve.
    Aug 06 2015
    Minnesota
    Update.... it was the DV it was stuck open. Greased it up cleared the code BOOST ON
    Oct 24 2015
    Perth, WA
    Thanks for updating mate.
    My respray thread
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by lostInTheSmoke View Post
    good stuff
    2008 A4 S-line 2.0T
    JHM Stage 2
    Nov 12 2015
    Orange County
    Was the DV the updated piston style or the diaphram? Also, 170k miles. Wow. Greating seeing these cars lasting this long.
    Dec 01 2014
    idaho
    Same thing happened to me, except my piston style diverter valve exploded. I contacted JHM (where I got it from) but they never responded. Part was out of warranty anyways, just wanted to know if the piston style was having issues...
    Aug 06 2015
    Minnesota
    Quote Originally Posted by zeitmorder View Post
    It was the piston style, and yeah she runs really good even with high miles. Here's the old DV I took out it was beat up to say the least.
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    That ain't a good cam follower. Since that coating had worn off it was just a ticking time bomb
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
