Results 1 to 7 of 7
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Those who have run 20" wheels
    I know this is a slightly heated debate; "handling this and handling that". But to those who have actually run 20" wheels and 19"s on their cars, was there actually a big difference? I know weight is a factor but I'd like to finally squash this debate as I am trying to decide between the two. I really like the look of 20" sitting under the wide arches but if there is a tangible performance loss I'm out.
    "Brake last, finish first."
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    I've heard for performance, you want the smallest/lightest wheel, and not the other way around. When I read the suspension/tire set up for track, I saw many running 18's over 19's.
    18 for track, 19 for street, 20 for picking up chica's.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Oct 13 2014
    I have run both. Avant Garde M310 for the 19" and BBS CH-R for the 20". I prefer the 19". My car is lowered and it seemed that the suspension wasn't as good at keeping the 20" under control. They would rub more when hitting bumps, especially large bumps on the freeway. The overall diameter and offset was the same with both setups so the 20" shouldn't have rubbed any more. I am assuming it is a result of the higher unsprung weight.
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    What's the debate? 19's come stock so not sure what you're asking?
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by badbluers4 View Post
    I know 19"s come stock...I maybe should have phrased the thread a little better. I was asking for a comparison between the two diameters and how people felt running 20s. I understand 18s would be best for track specific use, but on the street I also do not want to throw handling and ride quality by the way side for looks. I know there is a thread or two out there about this but wanted more input than what was available.
    Oct 27 2011
    Atlanta, GA
    Depends on your style. If you're more of the performance driving type then stick with 19. If you want to sacrifice a little bit of performance for better looks then go with 20.
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    And for ultimate performance go for the 18" that was the standard fit on the B7 RS4 in most of Europe (except the UK).
