Results 1 to 3 of 3
    Feb 26 2016
    Houston
    05 S4 B6 Fuel pump electrical issues
    I have been having fuel delivery issues that caused my S4 to stop starting. I replaced the fuel pump relay, fuel filter, fuel pump, and cleaned the injectors. The problem didn't go away so I checked the electrical running back and I am getting no power to either my fuel pump or my fuel transfer pump. The relay has power, but the fuse panel is not getting power for the fuel pump fuse. I am at a loss for where the power disruption is at now. It is somewhere between the relay and the fuse panel I guess. This is my first time posting, (I have been reading here for years and love the information it has provided) and I was just hoping someone would know. Thank you in advance and cheers!
    Nov 24 2010
    2015 A4 Premium Plus
    Lake Stevens, WA
    Try checking the ground connection on the firewall. It supplies a ground path to the ecu, fuel pump relay, and probably some other things that I haven't looked into. Mine was loose, causing a voltage drop at the ecu and fuel pump, thus not allowing the car to start.
    Feb 26 2016
    Houston
    Thank you very much for the response. I just double checked the ground and it appears to be good.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
